Keypad can be enabled in FORScan so long as you have it hooked up in the door harness. The code to enable it is in BCM below:
726-37-01 x*xx xxxx xxxx - Keypad Enable Cfg: 0=disabled, 1=enabled
If you have the Sync 3 8" screen you can also add the Door Keypad Menu to the settings, Vehicle icon with the following:
or send me a personal message rather than this New Member Intro thread.
AS BUILT
Iread somewhere on this site that in order to change the setting to get the key pad working i have to use instead os AS BUILT that I need to use
YOU MODIFY. I have no idea what they are saying.
my son is the one that has post to you about the new f250 diesel that the dealer is trying to hook up with no results. They ca't seem to find whete to change it. Have you every heard of this MODIFY?
we are both lost with this and from what I read you are the man! I am a retired Chrysler tech but its been a long time for me and I we don't want to mess this up. Is there anyway I can contect or you getting with me on this matter? I know more then him on some of this. Can you please help us out, I really need it and Ford seems to be blowing us off.
thanks
I got the Nuvision you recommended tablet. Im stuck and your video is very quick. Is there a step by step instruction for this tablet or general tablet?
I got everything set up w Nuvision 8 and obd2 mx bt......But it will not let us save or change anything. When u click on it the save file screen comes up but no keyboard on screen to enter a name of file. Also the same with enter any numbers to change. It clicks on but no keypad to allow the change of number. Please advise. Thx
