INTERIOR CODE
Old Jan 3, 2017 | 09:22 PM
swoosh1958's Avatar
swoosh1958
INTERIOR CODE
Can someone tell me where to look up interior codes? Or tell me which interior this truck has.
1966 F100 JM paint,Int E81?
Thanks
Old Jan 3, 2017 | 09:25 PM
TA455HO's Avatar
TA455HO
Lead Gopher
What year is your truck? The codes mean different things depending on the year.
In general one of the more complete references is the Master Parts Catalog, available on CD-ROM from HiPoParts.com
Old Jan 3, 2017 | 09:31 PM
swoosh1958's Avatar
swoosh1958
It is a 1966 F100. It has a JM paint scheme. Red and white.
Old Jan 3, 2017 | 09:55 PM
g4g2g7's Avatar
g4g2g7
Thanks
a helpful hint to save you time instead of awaiting replies: this forum has been around for many many years so the first assumption should be that most questions have already been asked one time or another. In the case of warranty plate info specifically, that happens several times a week, so if, for instance, you just type "1966 f100 e81" into the forum search function you instantly get a bunch of hits on threads that have the info you're looking for.
Old Jan 3, 2017 | 09:56 PM
TA455HO's Avatar
TA455HO
Lead Gopher
That is a great tip!
E81 is Red crushed vinyl and red cody pattern woven plastic.
Looks exactly like this.
Old Jan 3, 2017 | 09:57 PM
swoosh1958's Avatar
swoosh1958
Thanks, g4g2g7.
Old Jan 3, 2017 | 10:01 PM
swoosh1958's Avatar
swoosh1958
I am liking that seat!
Is there codes for interior dash,door colors?
F10AL888678
115 JM F100 E81 C09
05000 129 4000 63
Old Jan 3, 2017 | 10:09 PM
TA455HO's Avatar
TA455HO
Lead Gopher
F10AL888678
115 JM F100 E81 C09
05000 129 4000 63
Nope. Did ND or anyone decode that for you yet? You have all the known colors between the JM and the E81.
If padded dash then the padded portion was always black and there is a part number for that. Paint on the dash was typically tu-tone on a tu-tone truck, so should have been red and white on your truck.
Door trim panels were always color matched to the rest of the interior, but from a limited scheme of available colors. The MPC can help with what was available. Yours would have likely been white (probably) or red (maybe).
I need a passengers side that matches this one for my truck.
Old Jan 3, 2017 | 10:25 PM
swoosh1958's Avatar
swoosh1958
The dash right now is Beige on top and white on the bottom, doors are white.
How do you know if they came with a dash pad?
This is nice.
Mine has no white panels like yours and is missing the chrome dividing the face of the dash.
Old Jan 3, 2017 | 10:32 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, yours would have been more like the one with red doors, although a few things incorrect there, but closer.
I can see what appears to be holes in your doors for the trim and holes in the dash for the trim that runs horizontal.
Old Jan 3, 2017 | 10:54 PM
swoosh1958's Avatar
swoosh1958
Are those chrome pieces hard to find?
Old Jan 3, 2017 | 11:16 PM
TA455HO's Avatar
TA455HO
Lead Gopher
All of the trim is not reproduced for those two areas, so used is the only choice I know of. I believe the door trim metal is anodized aluminum. The dash pieces are the same anodized aluminum, I believe. Looks great - almost like chrome - until the anodizing wears off and the aluminum tarnishes.
If you buy the door trim surrounds make sure you get the complete set of 6 pieces and as many clips as possible (26 total were used). They reproduce those clips for $1.60 a piece at Carolina Classics.
The dash trim - there are 3 pieces. One long one that runs along the entire base of the windshield, one somewhat shorter one to the right of the dash opening that runs above the radio, ashtray and glove box area and a third piece to the left of the dash opening that is very short, just above the ignition switch area. Make sure you get all the clips that you can again. There are two sizes of clips, one for the dash face pieces and another for the one under the windshield and these are not reproduced.
Old Jan 4, 2017 | 03:05 PM
swoosh1958's Avatar
swoosh1958
This is a stock photo from Ford of the E81 interior. There is chrome above the door also.
Old Jan 4, 2017 | 03:16 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, also anodized aluminum - not chrome - and held on with screws. Not reproduced. Used is only source I know of again. I've picked up spares of all of this stuff over the years since they may not reproduce some of this stuff ever.
I have 2 trucks that are both 1966 E81 Custom Cabs but they did not come with the door trim panels or the trim over the door. Same seat as in your photo. But they are F250 4x4 so a bit more spartan even though Custom Cab.
Old Jan 4, 2017 | 03:23 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If DanK reads this - check out the upholstery alignment on the seat back....
You'll see what I'm seeing, I'm sure....
