1948 front assembly
Old Jan 3, 2017 | 03:21 PM
48bonus's Avatar
48bonus
4wd High
1948 front assembly
I have a 1948 F1 /F47 that came as parts lot and had been to more than one body shop !!. A lot of front fender repair has been done. I am trying to piece the front together , and have a 3/4 inch gap between the nose/ latch panel and the fenders. Looks to me that the problem is the radiator / inner fender support must be wrong . Can somebody please give me the measurement across the top of the support to the inner fenders. I might have a different / earlier model maybe that is making the fenders too wide. Thank you in advance.
Old Jan 3, 2017 | 03:48 PM
Bartman1959's Avatar
Bartman1959
Post a pic of the exact spots you want measured, and I'll measure my 48 F1 for you.
Old Jan 3, 2017 | 07:35 PM
48bonus's Avatar
48bonus
4wd High
1948 Front assembly pics
The measurement I'm after is the one between the two black arrows. (Across the radiator support). Other picture shows me pointing to the gaps I have and don't want!
Any suggestions and measurements would be great thankyou.
Russell
Old Jan 3, 2017 | 09:04 PM
Bartman1959
I'll see what I can do in the morning.
Old Jan 4, 2017 | 02:57 AM
FortyNiner's Avatar
FortyNiner
Did you assemble the front clip before installing on the frame?
Old Jan 4, 2017 | 03:13 AM
Mervy49's Avatar
Mervy49
I've put mine together there and taken it apart several times. I always put the inner fender 'inside' the front facia where you have yours on the outside, 'near' the fender. Try this a try and see if the gap is better. Mine fits up quite tight. Back off the fender bolts to give yourself some room to jiggle it a bit. You'll probably solve the gap. Cheers.
Old Jan 4, 2017 | 03:24 AM
48bonus's Avatar
48bonus
4wd High
No I did not assemble before installing on the frame. I loosely fitted the inner fenders, then the fenders followed by the grille panels , discovered the gap and can't see how to get rid of it. I wonder if the radiator support could be from earlier model ? Thanks
Old Jan 4, 2017 | 03:41 AM
Mervy49's Avatar
Mervy49
Your rad support looks like the right one as near as I can see.
Old Jan 4, 2017 | 06:35 AM
FortyNiner's Avatar
FortyNiner
What is the width measurement for your radiator support? Let's use the widest points by the arrows you drew.
While variations are to be expected, you have a cup in the middle of the span rod that doesn't match up with my 49.
Old Jan 4, 2017 | 09:54 AM
Bartman1959
I went out and measured mine this morning, and it looks to be 28 1/2 inches. Here are a couple of pics to go along with it. I hope this helps.
Old Jan 4, 2017 | 11:44 AM
49George's Avatar
49George
Rad Support
I went out and measured my 49 F47 at just under inches. I don't know what is going on with the middle cup. Mine does not have that.
Old Jan 4, 2017 | 12:41 PM
abe's Avatar
abe
Originally Posted by Bartman1959
I went out and measured mine this morning, and it looks to be 28 1/2 inches. Here are a couple of pics to go along with it. I hope this helps. [IMG]
That is dedication to the FTE cause! Trudging out there in knee deep snow just to get a measurement is above the call of duty. Cudos!
Old Jan 4, 2017 | 01:17 PM
Bartman1959
Thanks Abe, but that was the easy part. I went back out there and tried to get the 49 8N Tractor started, but it wanted no part of that. I have a carb kit for it getting delivered this afternoon, so I'm hoping the carb rebuild will straighten that out.
Old Jan 4, 2017 | 04:18 PM
48bonus's Avatar
48bonus
4wd High
Thanks for your reply . The measurement across the radiator support (at the arrows) is 28 & 7/8 inches. The cup thing in the middle has been a electrical relay , bet it was water tight !!!
Old Jan 4, 2017 | 04:40 PM
FortyNiner's Avatar
FortyNiner
So I would disassemble the front clip and reassemble in a different sequence. Might be best to build the entire clip and then install on the frame. If that isn't possible, then loosely assemble from front to back.
