Instrument cluster help?
Old Jan 3, 2017 | 09:07 AM
HouseMouse's Avatar
HouseMouse
Yesterday I took a long trip and explored the instrument cluster while driving. Anyway, found the DEF reading and it showed Full. Just to the left of the gauge there is a vertical bar graph of sorts(?) it has about 8 little squares that climb vertically and two squares from the top, one was light. After looking in the owners manual, I can find nothing to explain this "vertical Graph". Gauge says "Full" But, is the bar Graph an indication of 80% full ish?
Old Jan 3, 2017 | 09:28 AM
Rob_17's Avatar
Rob_17
The little squares you are seeing are the different monitoring "Pages" within that folder, such as DEF reading, tire pressure, transmission temp, etc... the reason for the illuminated one is that is the "page" you are on within the folder. It has nothing to do with your DEF level.
Arizona97
Dec 20, 2017 05:35 PM
pcman
Sep 20, 2017 03:07 PM
Tractionless
6.4L Power Stroke Diesel
Jul 19, 2017 03:50 PM
helifixer
Apr 7, 2015 07:53 PM
Dustin_86
Feb 18, 2006 03:50 PM
