I have an 89 E150 5.8 liter about a month ago then started running real rough figured it was a fuel filter the other day I drive down the street about 12 blocks and going to the store when I come out I go to start the truck and it starts real rough and will only run for about maybe two minutes and then stutter and then stop running I have 10 pounds pressure but do you believe that the Schrader valve not too sure which way to go I've been reading these post and it could be anything I guess and it will start right back up and do the same thing over and over and over again running for 2 minutes and then die any ideas thank you very much
