Fuel pump problems
Old Dec 30, 2016 | 10:08 AM
Mark Bieker's Avatar
Mark Bieker
Fuel pump problems
I have an 89 E150 5.8 liter about a month ago then started running real rough figured it was a fuel filter the other day I drive down the street about 12 blocks and going to the store when I come out I go to start the truck and it starts real rough and will only run for about maybe two minutes and then stutter and then stop running I have 10 pounds pressure but do you believe that the Schrader valve not too sure which way to go I've been reading these post and it could be anything I guess and it will start right back up and do the same thing over and over and over again running for 2 minutes and then die any ideas thank you very much
Old Dec 30, 2016 | 11:13 AM
annaleigh's Avatar
annaleigh
do you have duel tanks?
On this page you will find a diagram of your fuel pump system
https://www.ford-trucks.com/forums/1...l#post16735634
IT sounds like your high pressure pump is not working or you have a problem with your tank selector valve if you have duel tanks
https://www.ford-trucks.com/forums/2...re-issues.html
dirt_bag
Mar 30, 2023 10:32 AM
CowboyMike38
Aug 13, 2011 11:32 AM
forest337
May 6, 2009 01:38 PM
css123456
Mar 22, 2007 08:04 AM
master link
Aug 24, 2006 11:19 AM
