86 effi 302 got spark got fuel down 4 cylinders
I've got a 86 302 efi that has spark at the plugs on all 8 cylinders, I've got 50lbs of fuel pressure at the rail. I put a stephoscope on the injectors they all sound the same as far as clicks or pulses. I did a compression check 120 on a cold motor. Any ideas or suggestion would be great. It's cylinders 3,4,7,8 that are down
Also, a bit more history, please. Has the engine run well recently? Or was this a fresh rebuild or a junkyard find? Any recent work? The only thing that comes to mind right away is the spark plug wires out of order for the four suspect cylinders. That's where a bit more details and history will help.
Big thread here already for any history you might need. Can't fault him for starting a new thread, when they get several pages it's a hassle to try and get through them.
https://www.ford-trucks.com/forums/1...ease-help.html
My guess is they are dry. Even if they sound like they "clicking" does not mean they are not plugged and will not pass fuel.
You can try switching the good cly injectors to the bad and see what happens.
I also seen it posted some where on how to clean them but cant remember where it was. Then again they may be cheap $$ to just get new ones?
Dave ----
olgreymare86
1978 - 1996 Big Bronco
75
01-16-2020 03:20 PM
bpjpmo
09-16-2006 11:22 PM
1986_f-150
04-29-2005 07:59 AM
Pronounced"FORD"
02-27-2004 10:39 AM
