Air cleaner conversion
Old Dec 28, 2016 | 12:35 PM
firstrider's Avatar
firstrider
This was posted on a previous thread but made it much more simple . Just cut out the nine spider web supports . May drill some holes in the bottom with a uni bit .
Old Dec 28, 2016 | 12:48 PM
Mixer man's Avatar
Mixer man
Sweet! What's the part number for the element?
Old Dec 28, 2016 | 12:57 PM
firstrider's Avatar
firstrider
Bob , Fram CA568 . $13.84 at Oreilly
Old Dec 28, 2016 | 01:41 PM
dcavan001's Avatar
dcavan001
So that was the standard oil bath air cleaner to begin with?
Old Dec 28, 2016 | 02:52 PM
firstrider's Avatar
firstrider
Yes , have some more at my brothers in Wis.along with 12 More Magic Air heaters Be up there in Oct on the Great 2017 Parts Safari .
The oil soaked horse hair filament restricts the air intake quality & quantity .
Old Dec 28, 2016 | 03:36 PM
dcavan001's Avatar
dcavan001
I have a functioning oil bath air cleaner and was wondering how complicated it would be to change over to an air filter.
Old Dec 28, 2016 | 06:29 PM
CBeav's Avatar
CBeav
$3.45 @ RockAuto. Just bought two for $12.79 including shipping.
Old Dec 28, 2016 | 06:50 PM
dcavan001's Avatar
dcavan001
Air Cleaner conversion
Thanks - every now and then something is easier than you expect!
Old Dec 28, 2016 | 06:52 PM
firstrider's Avatar
firstrider
Take your snippers, cut the area around the 9 contact areas ,bend back towards the center bending them out of the way . snip the 9 spider web contact supports , pull out the innards , use your die grinder w/ a 60 grit wheel to smooth off the 9 points , clean out w/ mineral spirits ,install paper filter & you are done . 1/2 hour maximum time .
Old Dec 28, 2016 | 08:32 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Denny, did you have to put a flat plate to seal the top or does the top section seal against it?
Thanks for posting this!
Old Dec 28, 2016 | 08:37 PM
firstrider's Avatar
firstrider
The top seals against the filter quite firmly . When you tighten the wing nut you can feel it compress the filter a tad .Confident it will work just fine . Have 3 shows Jan 13 , 14 , & 19 .
Old Dec 29, 2016 | 12:40 AM
Mixer man's Avatar
Mixer man
Excellent. Thank you.
Old Dec 29, 2016 | 11:29 AM
Scotty's 52 F3
If anybody is interested, it crosses over to a K&N E-0870.
Old Dec 29, 2016 | 06:13 PM
firstrider's Avatar
firstrider
Give her some more air !!
Old Dec 30, 2016 | 08:39 AM
fordf348's Avatar
fordf348
I did mine this way, worked very well.
https://www.ford-trucks.com/forums/1...r-cleaner.html
