My tire guy is telling me that the new axle/hub on the my 2017 F350 is different than the previous years and that there is not a aftermarket rim that will fit them yet. His supplier told him that if the rear diff cover has 14 bolts, which mine does, that there is not a option out there as of now. Is there any truth to this? Thanks
i think the only issue you may run into is the center cap fitting on the rears. Other than that the bolt pattern is the same... I could be wrong tho
Well there is a ton of pics on here and on other sites with '17 SD with aftermarket wheels. Somehow they figured it out. I am guessing they are not a hub centric wheel and use a different offset. You should be able to go this route with your truck too. Or you can wait for companies to create a hub centric wheel like the OEM style wheels only sexier.
I think its a problem with SOTA wheels . I have seen a a lot of trucks with Fuel rims and American Force . I am waiting my American Force hurry and send them ......
