Rear end question, 2001
Old Dec 27, 2016 | 08:53 PM
Colorado Horseman's Avatar
Colorado Horseman
Originally Posted by Dan V
Your 95 has either 3:54 or 4:10.
So the axle tag is incorrect, or the axle has been 3.54 replaced with a 3.73?
OP stated axle code C1.
Old Dec 27, 2016 | 09:04 PM
Colorado Horseman
Sorry, I can't tell if OP is working on a 95 or some other.
NOTE: Tagline the vehicle you want help with! AND any mods! Sure would help me (and I'm sure a few others) FOCUS.
Old Dec 27, 2016 | 09:12 PM
Colorado Horseman
My advice would be to find a trading partner. When I had my big GN horse trailer, I would have liked the 4:10's.
I pull a fully loaded Circle J 4 horse with dressing room no problem over the divide - blowing Cummins away. 3.73's.
Whada ya want more than that?
Old Dec 27, 2016 | 09:26 PM
Colorado Horseman
Originally Posted by Jeff heine
Axle code is 01 (3.73) and the window sticker says 3.73 but its apparently a 4.11. 70 mph I'm turning 23-2400. My 95 is 1950rpm at 70. I try to stay at 2 when running down the highway for mileage. I'm planning on having this thing a long time. Should I change it out to a 3.73? I rarely pull anything and what I do pull a 6 cylinder could pull easily.
As compares with a few others I run 2025 RPM @ 70 MPH - 6spd 3.73.
If your axle tag says C1 (3.73) assuming AT and you are revving 2400, maybe you should log your torque converter slip.
Old Dec 28, 2016 | 12:07 AM
pirschwagon's Avatar
pirschwagon
Board, so I did some math (with the help of EXCEL);
R&P: 4.11
Tire Height 29.9 (Stock P235/75/16)
Speed: 70 MPH
Trans Ratio (4R100) .70
RPM's + 2,295 (say 2,300 as I only carried it to the hundreds)
R&P: 3.73
Speed: 70 MPH
RPM's + 2,083 (say 2,100 as I only carried it to the hundreds)
212 RPM Difference
Change ANYTHING in the equation i.e. Tire Size (Height) Transmission Ratio, etc., you change the end Sum.
Don't know the cost of change over. But, a cost comparison and increase in mileage would determine the cost effectiveness of the project IMO.
Old Dec 28, 2016 | 05:20 AM
Jeff heine's Avatar
Jeff heine
I'm talking about the 01, its a C1 axle code. I also have a 95. My convertor may not be locking up. What EPA mods are your talking about? Thanks for all the help
Old Dec 28, 2016 | 07:52 AM
Dan V's Avatar
Dan V
Here's the reason I would have preferred the 4:10's. I have enough power to pull that 26k lb load faster than it should be pulled...that's not a question.
The reason is I prefer to tow 26k at a reasonable speed....60-65 mph. That puts the rpms around 2k. In my opinion there is a significant tendency lug and create high EGT. The 4:10 would give me a couple hundred rpm to offset that.
My 95 had 4:10's...didn't make near the power that my 01 does, but I felt it was more driveable at my preferred towing speed.
Old Dec 28, 2016 | 11:36 AM
Colorado Horseman
Good point!
I don't mind 70 mph on typical flatland interstate hwy, definitely too fast for two lane or mountain roads - particularly downhills!
I have the 6spd, and prefer 18k-22k RPM for best MPG/power range. I tend to shift to achieve this.
Old Dec 28, 2016 | 11:52 AM
Colorado Horseman
EPA has forever forced manufacturers to meet constantly more restrictive standards. The electronic engine management of modern vehicles was not introduced to improve performance or durability, but to meet EPA expectations.
Many of the new designs and modifications manufacturers have come up with are prioritized to meet these arbitrary EPA edicts without reducing performance - maintenance and durability issues be damned.
turnkyle
May 17, 2011 05:09 PM
geborenzuschaukeln
Apr 12, 2005 06:13 AM
buckcreek
Feb 23, 2005 08:11 AM
1990Fordf150v8
Jul 14, 2004 08:17 PM
Gobstopper909
Nov 4, 2003 08:26 PM
