95 7.3 will not start
Old Dec 25, 2016 | 04:47 AM
95444stroker's Avatar
95444stroker
Ok so i just got anouther 95 powerstroke i got it not runnig for what i thot was a good deal i took it to my freind with a scanner he said everything looked fine except the cam sensor so i got a ford motocraft one took the old grey one out put the new one in nothi g but the rpms r showing around 500 now so began going threw the truck and noticed a fuel bowl delete kit with no regulator so i got a nice fuel lab regulator put it on and i get 50 psi on fuel still wont start and no smoke out the tail pipe and am getting a wait to start light like normal so i took the idm out of my other truck and nothing then i unplugged my ts 6 pos chip still didint change so i lokked at the icp and it was covered in oil bad and i looked at the ipr pig tail and it was covered in oil to so i replaced both today still no luck then i tested the glow plugs turns out all 4 on the passenger side are bad driver side was fine replaced those still didint do anything i tested the bats they hav 14 volts and when i crank the motor they drop down to 11.5 and im starting to run out of ideas if anybody has any idea or can help i would really appreciate it i really wanna hear it run so bad
Old Dec 25, 2016 | 08:42 AM
oldbird1965's Avatar
oldbird1965
No smoke out the tail pipe, no fuel. Follow this and see if it helps:
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Old Dec 25, 2016 | 09:11 PM
95444stroker
I
It has 50 psi it gettiing fuel
Old Dec 25, 2016 | 09:14 PM
95444stroker
I
The chart leads me to the ipr wiring is bad or wrong ill check that tomarrow thanks
Little33456
Oct 24, 2018 06:21 PM
jungles82
162
Mar 20, 2018 02:05 PM
aqnhfd
Jan 14, 2018 01:53 PM
Pocket
57
Sep 22, 2010 11:38 AM
Pocket
45
Sep 15, 2010 10:16 AM
