Stalled & stranded
Old Dec 23, 2016 | 03:33 PM
phoskins's Avatar
phoskins
Stalled & stranded
'96 F150 4.9 4x4 just quit running and won't restart. I was trying to pull out of a parking lot. I have spark, new fuel pump, new battery, new starter. Engine cranks but won't start.
I have called a tow truck and they'll be at least an hour. Is there anything I can try to get it to start? Solenoid? Where is it?
Thanks to anyone who might be able to help.
Old Dec 23, 2016 | 03:48 PM
ncranchero's Avatar
ncranchero
Can you hear the pump running?
Check the inertia switch behind the passenger kick panel. smack it good and hard to trip it then press the red button.
Old Dec 23, 2016 | 04:59 PM
joey2fords's Avatar
joey2fords
if it's cranking it's not the solenoid, or anything else starter related.
the PIP will often fail intermittently, before it fails for good. try BRIEF attempts at starting every few minutes, so that you dont run down your battery ... you may get lucky and have it catch.
Old Dec 23, 2016 | 05:01 PM
joey2fords's Avatar
joey2fords
oops, missed the part about having spark. but it could still be the pip, failing intermittently. check the connector under the efi relay . they can get clustered.
Old Dec 23, 2016 | 06:47 PM
phoskins's Avatar
phoskins
joey2fords, THANK YOU! I'm thinking that's what it is, the PIP sensor failing intermittently. After an hour & a half of occasionally trying to start it, it started! How hard is it to replace the distributor? I gather it's just better to replace the entire distributor than to just replace the PIP. I've already replaced the ignition module, coil, cap, rotor, plugs, wires, battery, starter, rear fuel tank & pump.
Old Dec 23, 2016 | 06:50 PM
phoskins's Avatar
phoskins
I can hear the pumps prime when I turn the key. Inertia switch is always a good thing to check, but it wasn't the problem in this case. Thank you for the tips, though!
Old Dec 23, 2016 | 07:18 PM
joey2fords's Avatar
joey2fords
swapping out a distributor is not rocket surgery , but i would pull codes first before tossing parts around.
Old Dec 24, 2016 | 09:29 AM
subford's Avatar
subford
If it had spark and not start it is not the PIP sensor.
If the fuel pumps ran all the time with the key on when it would not start then I would say you have a bad PCM Computer.
Old Dec 26, 2016 | 02:05 PM
phoskins's Avatar
phoskins
Yes, that makes sense. I was wrong in my original post, I did not actually confirm I had spark. Thanks subford.
Old Dec 26, 2016 | 02:21 PM
subford's Avatar
subford
Dose the MIL (CEL) go out while the engine is cranked?
Old Dec 26, 2016 | 02:39 PM
phoskins's Avatar
phoskins
The CEL lights up when key is turned to run. CEL stayed lit when I cranked the engine, if I remember correctly. When it finally did start, I drove it straight to the shop, as my insurance company wants to drop tow coverage on my policy. I can't afford to have it leave me stranded these days. There was no CEL lit when it started. Shop can't look at it until tomorrow. I try to do as much of my own repairs as possible, though, & would like to give the shop as much info as I can. Guess I'd better hope it's the PIP sensor.....
Old Dec 26, 2016 | 03:56 PM
subford's Avatar
subford
When it does not start if the CEL does not go out while the engine is cranked the the PCM Computer is not receiving the PIP from the distributor PIP sensor mounted on the stator assembly.
Note that a lot of the rebuilt distributors have bad PIP sensors in them.
Old Dec 27, 2016 | 01:43 AM
Jjona5's Avatar
Jjona5
Put a fuel pressure gauge on it. You can cheat and use a tire gauge a few times but it will kill it eventually. My money is on not getting fuel. (could be filter, could be switcher, or a numbe rof things).
Old Dec 27, 2016 | 08:19 AM
phoskins's Avatar
phoskins
By "switcher", do you mean the tank selector switch and the mechanism(s) it controls? I didn't have a fuel pressure gauge when I was stalled, or I would have done that. Fuel pump relay, fuel filter, rear fuel tank & fuel pump are new. Front pump & tank are old, but I was running on the new one when this happened. When I switch tanks, it functions correctly. Fuel pressure readings were within specs on both tanks when I tested them after the last time this happened. When it did start, it ran great.
This is an intermittent problem, when it happened before, it didn't actually stall while driving, but it wouldn't start, & it was totally random.
I've suspected fuel issues too, but why would fuel pressure just drop suddenly & then stay low for an hour & a half, then increase suddenly, enough to start & run? Fuel pressure regulator seemed to be working just fine before, when I tested the pressure.
Old Dec 27, 2016 | 12:01 PM
Jjona5's Avatar
Jjona5
I just noticed you have a 96. You don't have a switcher, you have check valves that do all of the switching. My truck recently did something like you were describing but my rear pump was already acting up. Then the check valve failed slightly so my front pump was running but it was losing pressure due to bleeding off into the back pump.
