desperate help needed
Old Dec 22, 2016 | 09:33 PM
SuperB's Avatar
SuperB
Been on here for a long time as a lurker for knowledge ... now I can't find what I need. Here's the story .... e99 F250 with a 2001 motor swap and is a 6 Speed. Bought it this way and to be honest it was a cobbled up mess ... but it was stupid cheap. Motor had couple issues. Transmission broke so I had trans rebuilt and different motor put in (lower mileage, new oil pan, new up pipes, supposedly rebuilt injectors). I get the truck back and guy says it smokes whenever the accelerator is pushed and he thinks some orings have gone bad (on rebuilt injectors according to him) and he gives me another set of rebuilt injectors. Replace injectors and a crap ton of other parts that were wrong, bad, rigged, etc. All that to say that I am still having an issue I had with previous motor. Anytime I cross, roughly, 40% throttle above 2500 rpm it bucks (hardcore miss) and losses power. I am fairly certain it has an Auto tranny PCM in it but from what I have gathered it doesn't matter, PLEASE LET ME KNOW IF THIS IS FALSE. I have been using my 01 X 7.3 for reference PID info but am not seeing any difference. Plan to Data Log it with AE as soon as I can. Just checking to see if anyone had similar symptoms.
Thanks in advance for any info. I am not a knowledgeable computer savy guy. Cannot figure out how to specify search terms. Any and all "tools" for this not savy guy is appreciated.
Old Dec 23, 2016 | 12:46 AM
timmyboy76's Avatar
timmyboy76
Check ICP for oil in plug. Maybe the hutch mod can cure it...
Old Dec 23, 2016 | 08:35 AM
Walleye Hunter's Avatar
Walleye Hunter
It does sound like a fuel problem and I'd check in the tank. Try pulling the fuel line off of the rear of the fuel pump and blowing air back into the fuel tank. The pump is inside the frame below the driver's seat. Remove fuel cap first. That should temporarily dislodge anything clogging your fuel intake. The hose is only held in place with a white plastic horseshoe clip, then pulls right off. Easy on that clip though or you'll break it. I recommend buying new one first because they are brittle. It seems that all auto parts stores have them.
Old Dec 23, 2016 | 04:05 PM
SuperB's Avatar
SuperB
thanks for the replies. Hutch mod performed last fall. Along with diesel site's filter setup and a new fuel pump. Waiting on a fitting to test fuel pressure. Previous motor (bad oil pan and injectors... got this motor for a little more injectors) did the exact same thing as this one.
I won't make it back down to the shop til Monday afternoon. Happy Holidays!!
Old Dec 23, 2016 | 04:30 PM
guitarpicr's Avatar
guitarpicr
How is wiring at the vc harnesses ? Did you swap these to newer motor
Old Dec 23, 2016 | 04:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by SuperB
. I am fairly certain it has an Auto tranny PCM in it but from what I have gathered it doesn't matter.
Uh huh...
Get the ID engineering number off the computer and post it here, I'll see what its applications are.
Old Dec 23, 2016 | 07:43 PM
SuperB's Avatar
SuperB
Replaced them and the glow plugs when I was tracking the issue last spring. Yes they have been moved to the new motor.
Will do when I get back to the shop Monday.
Old Dec 29, 2016 | 01:46 PM
SuperB's Avatar
SuperB
Tag on the PCM reads 1C3F-ZC and PMT2 then in small print 610043.
Old Dec 29, 2016 | 01:53 PM
SuperB's Avatar
SuperB
Little update ... Hooked it up to AE and found P1293 and P1294 codes and I found that the Intake temp sensor was MIA. I am picking up contact cleaner and dielectric grease tomorrow to tackle that as I found a couple threads where these were solved by a good cleaning. Picking up the sensor as well.
I will also be testing the fuel pressure at the outlet of the fuel bowl as I picked up the fittings I need to hook a gauge up. If that shows up funky I plan to work my way backwards to the pump.
Old Dec 29, 2016 | 02:41 PM
bigb56's Avatar
bigb56
Good plan, there have been a few instances where the Hutch Mod went bad, ie: pinched line when putting tank back in, bad clamp job causing air, broken pickup foot etc.
Old Dec 29, 2016 | 03:04 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I was one of these people that spent a lot of time getting the tank back in. Luckily I inspected the lines just before securing the tank in place and saw that the lines were twisted and crimped for the most part. I ended up having to lower and raise the tank several times in order to get the lines in the correct orientation when the tank was put back in place.
The truck is much better since the hutch/harpoon mods, but it was a tedious task.
Old Dec 30, 2016 | 12:31 PM
hydro man 17's Avatar
hydro man 17
When using dielectric grease be sure to keep it away from the actual contacts on the plugs ETC. It is actually an insulator and should be used as a sealer.
Old Jan 1, 2017 | 08:22 PM
SuperB's Avatar
SuperB
Quick update ... Cleaned harnesses and connectors. Inspected connector seals and all is well there so I skipped the grease. Tested valve cover harnesses, then tested to 42 pin and all is well again. Didn't have the time to tackle the fuel pressure gauge stuff do some needed maintenance on the wife's Excursion (yep another 7.3). Should have some more data next weekend. Thanks to all who have offered advice!!
Anyone have any info on the PCM info in post #8?
3KP
May 26, 2014 12:37 PM
Kdr358
Sep 3, 2012 04:30 PM
traxx808
Nov 29, 2010 12:31 PM
jwhitetail
18
Jul 17, 2010 11:27 AM
725franky
Jul 14, 2005 05:41 AM
