Speedometer Bounce...
Old Dec 22, 2016 | 11:19 AM
KsHighboy's Avatar
KsHighboy
Just curious if the speedometer in your guys trucks ever make a noise and bounce around when its really cold? My speedo has always read off and bounced around when the temps got down into the single digits. After I drive it awhile and things warm up it works fine. My dads old 69' did the same thing and my brothers 71'. It has been cold here lately and wondering if something finally grenaded in the cluster causing my speedometer to quit cause the gear and cable are fine.
Old Dec 22, 2016 | 11:26 AM
mikeceli's Avatar
mikeceli
Mine doaent, but i have owned vehicles that did. try this. You have to pull the cluster.
Dorman Champ 9-1812 - Speedometer Cable Lubricant | O'Reilly Auto Parts
Old Dec 22, 2016 | 01:12 PM
dfdiamond's Avatar
dfdiamond
Mine bounces like crazy but smooths out around 50 or so and reads dead accurate from there up.
Old Dec 22, 2016 | 01:39 PM
Freightrain's Avatar
Freightrain
Yup, you need some lubricant on the cable.
Pull the cluster, remove the cable nut and then you should be able to pull the inner cable out. Get some graphite on it, just a light coat, don't over do it. Then slip it back in and you should be good to go.
Old Dec 22, 2016 | 01:46 PM
gittinwidit's Avatar
gittinwidit
I've got a 76 maverick that not only bounces, but the needle does 360's after you hit 70+. Talk about a conversation piece. I like it since I really don't even WANT to know how fast I'm going in a tin can on wheels after 70...
Old Dec 22, 2016 | 02:04 PM
KsHighboy's Avatar
KsHighboy
Freightrain, I have put prob 2 or 3 different cables on my truck over the last 24 years and it has always done this even when lubed.
Old Dec 22, 2016 | 02:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When was the last time you lubed the speedo cable and what did you use to lube it?
When the lube dries out, the inner woven steel core (available from auto parts stores-cut to fit) binds up inside the housing, eventually snaps.
Ford originally sold speedometer cable lubricant, which was white lithium grease. Today, most people use graphite.
Old Dec 22, 2016 | 02:21 PM
351Cleveland C4's Avatar
351Cleveland C4
Mine bounces below 20. Not real bad though.
Sometimes it will also swing back and forth from 60-70 when I'm on the highway.
Old Dec 22, 2016 | 05:11 PM
KsHighboy's Avatar
KsHighboy
Numbers, I put a new cable in prob 3-4yrs ago. Cant really remember what I used to lube it. Pulled the cable last night and it looks great but I picked up some spray graphite lube from NAPA today and will try it when I reassemble.
Old Dec 22, 2016 | 06:17 PM
gangstakr's Avatar
gangstakr
Come on guy's/gal's think old school, how do we solve this problem? Lets go back to basic's.
First verify speedometer is working. Next make sure you have a gear for the cable. (I won't go into detail) Last, mix up some ATF and white lithium grease. Remove cable from both ends. Get your cordless drill out. Stick one end of cable into solution, the other to drill. Now run drill in reverse while cable is in solution. Let cable get lubed and your done. Unless your outer cable is bent and or damaged, then of course you need a new cable.
These are simple fixes that just require 1% of brain.
Old Dec 22, 2016 | 07:08 PM
sandman2102's Avatar
sandman2102
My speedo would bonce all over. Decided to clean everything up. Pulled the whole cluster. took it all apart ...painted, polished clean plastic,the added a little light oil to the speedometer moving parts. Put it back together and no more bounce!!!
Old Dec 22, 2016 | 08:17 PM
orich's Avatar
orich
Sometimes the cable housing is old and to sharp of bends in it when al else fails.
Or your tired of looking at that old cluster, then do like many of us have done.
Build yourself a custom dash with one of the newer high teahs electronic /gps speedometers. No more changing drive gears fi you switch to a different size of tire.
Just mark out a mile them push a button starting a mile then press at end of mile it's now recalibrated for the new tires an done.
Orich
Old Dec 23, 2016 | 12:49 PM
JEFFFAFA's Avatar
JEFFFAFA
Sometimes the inner core wears in to the inside of the cable's housing. Lube doesn't help much for this. There was one time Long ago a customer brought in his old cable assy as a sample. The inner core had worn "through" the outer housing!
Old Dec 23, 2016 | 12:59 PM
mikeceli's Avatar
mikeceli
I'd avoid the white lithium grease because, over years of air exposure, it gets thick and sticky.
Old Jan 26, 2017 | 11:21 AM
JEFFFAFA's Avatar
JEFFFAFA
I just ran across Ford's PTFE lubricant for driveshaft slip yoke splines is also recommended by them to lube speedo cables. It's still available from your local Ford Dealer.
Ford Motorcraft part number XG8A is a 1 lb. container.
Ford Motorcraft part number XG8 is a 3 oz. tube.
Mikemakeswine
19
Nov 19, 2017 01:17 PM
GeneGregory
Sep 15, 2015 05:15 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Dec 16, 2013 12:34 PM
Dustin_86
Nov 1, 2004 10:17 PM
GammaDriver
Jul 4, 2002 09:59 AM
