Steering Wheel Repairs - Does and don't!
Old Dec 19, 2016 | 08:26 PM
Moe Craig's Avatar
Moe Craig
Here is my cracked old steering wheel.
Well like many others, my steering wheel (bakelite) has cracks and missing small pieces, so it need some repair. I'm looking for help from others to see what they used and did. I've heard of people using PC-7, JB Weld, and many other kinds of 2 parts epoxies. What year is your steering wheel from? What did you use as a filler (epoxy)? How long ago did you do yours? What kind of paint did you spray afterwards? How is yours holding up? If there is something you would do different this time?
Old Dec 19, 2016 | 08:37 PM
FortyNiner's Avatar
FortyNiner
I used POR 15 putty and painted with POR 15 paint. The paint adhered well to the 'chalky' wheel surface and has held up well for 5 years. It is showing some wear and will need a recoat next year.
Old Dec 19, 2016 | 08:39 PM
EFranzen's Avatar
EFranzen
I repaired mine with PC7 and painted with Topcoat by POR15. I dries rock hard, doesn't soften in the AZ sun and is UV resistant.
Here's a before and after that I completed this past February.
Ernie
Old Dec 19, 2016 | 08:40 PM
49willard's Avatar
49willard
I have done 2 wheels over time, a 1938 Woodie Banjo wheel in the 80's and an antique boat wheel last year. I used PC-7 both times. I used acrylic enamel and on the banjo wheel used a flexible additive. Not sure that the additive was required.
Old Dec 19, 2016 | 08:49 PM
df85732's Avatar
df85732
Thanks for bringing this topic to the top Moe. This is one thing I can work on during these cold and snowy days this winter. I will be following closely. By the way, yours looks awesome EFranzen!
Old Dec 20, 2016 | 09:28 AM
CharlieLed's Avatar
CharlieLed
Beautiful job Ernie!
Old Dec 20, 2016 | 09:40 AM
SierraPapa's Avatar
SierraPapa
Ernie
Any step by step's on this method? That looks amazing btw.
Old Dec 20, 2016 | 11:49 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Most of the threads I read said be sure to groove all cracks down to the metal to get good adhesion. Many advised to use plastic adhesion promoter which I did. I had planned to use JB Weld but read some disappointing threads about it separating and swelling. Since this is not a science it could be that the bad JB Weld threads were bad preperation.
My wheel is a 64 Galaxie, whatever it's made of is very soft (or decomposed). I've just got it in primer and am planning on using rustoleum rattle cans to match my interior.
Old Dec 20, 2016 | 04:32 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Great thread!
I'm looking forward to learning something here as I need to freshen up the 64 Buick wheel in my 49
Bobby
Old Dec 20, 2016 | 07:51 PM
EFranzen's Avatar
EFranzen
I used a die grinder to open the cracks a little bit and then sandblasted the rusty bits. I then applied PC-7 to the cracks being careful not to gob on, as that just means more sanding.
Once the epoxy dried (several days to make sure it wasn't going to shrink), I filed and sanded. This was a longest hardest part.
Once sanded I sprayed with TopCoat \ Black Coat by POR15.
Here's a photo of the wheel after applying the PC-7, but before sanding.
Ernie
Old Dec 20, 2016 | 07:57 PM
49f68canadian's Avatar
49f68canadian
mine was really rough, so i guess i was lazy and purchased exact reproduction one from Mac's for around $200. Thanks
Old Dec 21, 2016 | 10:24 AM
CharlieLed's Avatar
CharlieLed
I use silicone putty for many of my projects when I need to capture a contour to copy to another section. In the case of a steering wheel, the putty can be used to make a mold of a good section of the wheel and then the mold is used when the PC-7 is applied to hold the repair epoxy in the exact shape of the wheel. Sanding and reapplication of epoxy is kept to a minimum.
Old Dec 21, 2016 | 10:32 AM
abe's Avatar
abe
So, is the general consensus that PC-7 is a little bit better than JB Weld?
Old Dec 21, 2016 | 11:12 AM
Moe Craig's Avatar
Moe Craig
At first I only heard of people using JB weld and then heard of people using POR 15 Putty. But now I been finding more and more using the PC-7. I have an extra wheels (thanks Tyler S) to play with... Anyone have a failure (DON'Ts) store to tell use to steer clear of?
CharlieLED,
What kind of silicone putty are you using? Is it the really soft molding putty? How are you securing it to the wheel (binding or wrapping it)?
Old Dec 21, 2016 | 12:24 PM
CharlieLed's Avatar
CharlieLed
Here is one of many silicone putties available EasyMold® Silicone Putty The putty has a consistency of soft bubble gum and needs no support to hold it in place. On a steering wheel rim I would mold the putty around the rim and then make a cut in it when it has cured (20 mins) to remove it. When using it on a repaired area all that you need to do is prep the damaged area, apply your repair epoxy to fill the void, and then place the silicone mold over the repair to "mold" the epoxy to shape. At best you might need a strip of masking tape to hold the mold closed...this depends on how thick you made your mold. Nothing sticks to cured silicone so there is no need to prep your mold, it will peel right off the cured epoxy.
