Sponsored by: Real Truck
2012 6.2L Eats Batteries?
Old Dec 22, 2016 | 07:47 AM
  #31
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by Firekite
For what it's worth, Deka makes all the automotive batteries for Duracell. So next time you need a battery for any vehicle, stop by Sam's Club and see if they have one of their AGM batteries in stock. It's going to be the sweet spot of the lowest price for the highest quality battery you'll find.
I will check them out the next time I need a battery. Thank you for the tip.
Old Dec 22, 2016 | 07:51 AM
  #32
99f350sd's Avatar
99f350sd
My truck charges at 14.7volts...Much above that is prob no good. I have an ambulance regulator...cause I have a winch a plow and elec sander and too many lights lol.
Sounds to me like you have a draw somewhere killing the batteries...test the amperage with the truck sitting a while...20 to 50 ma..no hood light and after 15 mins of not touching the truck. I use a clamp on dc amp meter or a direct connect.
Oh I use the biggest deka I can get... they are great.
Old Dec 22, 2016 | 07:57 AM
  #33
RV_Tech's Avatar
RV_Tech
Here's an aside about battery manufacturing. When our number one son decided to devote his first year of college to chasing girls and playing the guitar, an "education" for which we were paying, we decided his time could be better spent working - on the night shift at a local battery plant.
Since they made batteries for under a number of names and in a variety of price ranges, I asked him what the difference was. He said they had to check the voltage of all the batteries as they came down the line. The highest end batteries had to show 12.7 VDC on the meter. Other batteries might show just 12.5 or 12.6 VDC. I thought that was interesting.
And having his clothes literally turn to taters from his work convinced him a college education was a worthwhile endeavor, after which he became a highly successful computer programmer.
Steve
Old Dec 22, 2016 | 08:17 AM
  #34
airm4n's Avatar
airm4n
I've been running either Schumacher automatic onboard battery chargers or the genius marine type that I wire in with my block heater. Up until I sold my jeep 2 years ago I had at least 10+ years on a blue top optima and 7 or 8 years on 2 red tops. I just plug in and come out to a fully charged battery. I suppose that could cause problems but i've never really had much in the way of battery issues that some do.
Old Dec 22, 2016 | 08:49 AM
  #35
RV_Tech's Avatar
RV_Tech
I am not sure how many folks actually have battery problems. I think the folks who have bad luck post and the folks who have good luck are more likely to post. All the folks who have no strong feelings either way just go about their business. In terms of problem children, batteries would never make it onto my list, regardless of brand.
Steve
Old Dec 22, 2016 | 09:59 AM
  #36
Sir Kayakalot's Avatar
Sir Kayakalot
I had the same problems with my batteries draining down on my 14' F350. After the first 2 batteries failed in the first year I put a battery tender on and have not had anymore problems. At least Ford covered them under warranty so I was thankful for that. So I guess I said all of that to say this.... Battery Tenders are your friend.
Old Dec 22, 2016 | 10:37 AM
  #37
RV_Tech's Avatar
RV_Tech
Nothing against battery tenders, but I don't think the majority of owners require them to guard against battery failure. I am guessing repetitive failures have more to do with battery quality overall. Just my opinion.
Steve
Old Dec 22, 2016 | 01:16 PM
  #38
Wingit929's Avatar
Wingit929
Steve
I have a friend in the battery industry. He says the same thing.
Old Dec 22, 2016 | 01:17 PM
  #39
Wingit929's Avatar
Wingit929
It sounds like you had them when they were a good product.
Old Dec 22, 2016 | 01:35 PM
  #40
MarkyB98's Avatar
MarkyB98
I had an 05 Expedition (5.4L) that would eat batteries every 2 years..
I just noticed this week my 2016 6.2L SD is cranking a little slow. Perhaps the cool weather is exposing a weakness. I should get it tested tomorrow.
Old Dec 22, 2016 | 01:49 PM
  #41
ford390gashog's Avatar
ford390gashog
As far as my understanding of the intelligent battery monitoring system for 2011+ vehicles goes they don't like batteries that are not lead acid. You actually need to pull up the battery health and history using the IDS and reset for a new battery. This is where you will see the in service time , charge, discharge rate and temperature. The system is not setup to monitor the temperature of AGM batteries. I believe there is mention of this in the service guide. Also a deep cycle battery is a bad choice as a primary battery. You would have been better off with a red top. The alternator is trying to charge the yellow top faster then the AGM can take it and the Intelligent Battery system can't judge battery temperature and is probably cooking the battery.
Old Dec 22, 2016 | 05:00 PM
  #42
Firekite's Avatar
Firekite
@ford390gashog I can't find anything about any of that in my 2011 F250 6.7L owner's manual or diesel supplement. Please double check.
Old Dec 22, 2016 | 10:23 PM
  #43
djm1204's Avatar
djm1204
my 2012 F350 6.2 4x4 has 60,000 miles and it's original battery, no issues (yet)
Old Dec 23, 2016 | 05:07 AM
  #44
seville009's Avatar
seville009
I change mine out every three years. For $100, gives me peace of mind that it will start when it's cold or storming out.
Forgot to do that in my 2011 last year, and sure enough it died on me (about 40 months old).
Old Dec 23, 2016 | 12:47 PM
  #45
ford390gashog
This will be in the repair guides.
