Starter whining
Old Dec 18, 2016 | 10:15 PM
vrinner's Avatar
vrinner
Starter whining
'03 7.3 with 165,000 miles.
Went to start tonight and the starter would start to crank the engine over then the starter would disengage and make a high pitched whining sound. Wait a few seconds and sometimes it would just whine and sometimes it would attempt to turn the engine over. Tried about 10 times and engine never cranked enough to start.
1st time it's ever done this. Sitting for about a week. Colder than normal temps.i have noticed engine cranking slower than normal the last month or so.
From what I've read I'm thinking (hoping ) it's just a bad ground or loose wire.
Old Dec 18, 2016 | 11:29 PM
Tuquala's Avatar
Tuquala
Betting on a bad starter drive. It has a one way clutch and if goes bad, the motor will just spin, gear won't turn, engine won't start.
Old Dec 19, 2016 | 10:50 PM
vrinner's Avatar
vrinner
I put a charge on both batteries to make sure they were fully charged. Did the same thing. First try heard just a high pitched spinning noise from the start. Turned off, waited a few seconds, turned to on, waited for normal glow plug lights on dash to go out, turned to start, cranked about 1/2 a second then made the high pitched spinning noise. Hit start one more time and just got the high pitched noise and spinning sound.
Old Dec 20, 2016 | 12:02 AM
Tuquala's Avatar
Tuquala
You need a starter!!!! The drive is bad.
bassranger8722
13
May 19, 2015 07:01 PM
FordNFishinLover
Aug 5, 2009 11:41 AM
FordF350Baby
Jul 2, 2008 04:21 PM
DirtStripHero
16
Jun 9, 2008 05:58 PM
dreo2003
15
Jan 20, 2008 11:14 PM
