U joint issue
Old Dec 17, 2016 | 08:09 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
U joint issue
It took 12 hours but I got the rear axle swapped and now there's a u joint issue
it's too wide for the axle the u joint is 3 5/8 across but seems to have the correct size caps
I was told the axle has a 1310 yoke I believe it's all stock but I'm not sure and the driveshaft has been replaced
Old Dec 17, 2016 | 09:11 PM
tabascom16's Avatar
tabascom16
The u-joint sizes I know about are:
1310
1330
1350
1410
3 5/8 sounds like a 1330 or 1350. The 1350 has larger diameter caps but same width.
1310 should be narrower than 3 5/8 but may have the same cap size as the 1330 or smaller. Considering you have caps that match I bet you have a 1310 to a 1330 issue.
You can order special u-joints that are combination sizes.
Old Dec 17, 2016 | 09:17 PM
Rollingscrapmetal
Can I just swap the axle yoke
Old Dec 17, 2016 | 09:22 PM
tabascom16's Avatar
tabascom16
You can. They can be a real pain to get off, and to properly torque down. Also it can mess with the pinion preload. If your axle has a crush sleeve type system you can alter how the pinion mates with the ring gear inside the axle.
Your choice.
What axle are you working with? 9", D60?
Old Dec 17, 2016 | 09:24 PM
Rollingscrapmetal
Dana 60 rear
Old Dec 17, 2016 | 09:25 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Maybe this will help?
Old Dec 17, 2016 | 09:33 PM
tabascom16's Avatar
tabascom16
I am finding conflicting evidence on whether the D60 use a crush sleeve or shims. I will tell you this though, a 1/2 impact wrench is not going to get the nut tight enough. I had tried a few times with an impact wrench only to have the nut come lose and wondering what the sounds coming from my rear axle were. And you cannot just get a breaker bar and pipe on it to torque it down either as the drive system flexes enough your breaker bar and pipe will hit the ground before you can even torque it.
It seems crazy to me a D60 would have a 1310 yoke on it. What did it come out of?
Old Dec 17, 2016 | 09:49 PM
Rollingscrapmetal
74 highboy
it matched the front axle the big kind of dana 44 closed knuckle
Old Dec 18, 2016 | 12:00 AM
Rollingscrapmetal
so it is do able but what can I do to prevent that
I couldn't tell you if it's a 1310 or whatever else but it is a lot narrower than than the u joint that is on it
Old Dec 18, 2016 | 12:01 AM
Rollingscrapmetal
Apparently I messed with your quote
Old Dec 18, 2016 | 10:57 AM
tabascom16's Avatar
tabascom16
Look at the dimensions on this conversion u-joint. I feel pretty confident you have a 1310 and 1330 issue. You could probably order the MOOG 253 ujoint locally and they would have it for you tomorrow if your local napa, advance auto, carquest, etc don't have one in stock.
https://www.summitracing.com/parts/mog-253/overview/
The more I search around the internet it seems that later D60s have crush sleeves, but out of this era of truck it should only have shims. The issue then would be can you torque the nut down enough. I ended up using a 1" impact wrench from a relative to finally fix my problem. Final torque was unknown. A 1/2" impact wrench just cannot torque the nut enough because the internal workings of the axle give and flex, absorbing the energy to torque the nut.
I really do not know of an accurate way to torque down the pinion nut. I have tried several over the years with no avail other than the 1" impact wrench which likely applied more than the normal amount of torque.
Old Dec 18, 2016 | 11:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No Dana axle of any year or type has a crush sleeve.
Only the 9" has a crush sleeve (B7A-4662-A), 9's were only installed in F100/150 & Bronco.
The 1310/1330 "conversion" u-joint (2 cups are 1310's, two cups are 1330's) is Ford part number: C5TZ-4635-F .. The Spicer part number: 210392-X
1973/79 F250/350 Dana 60; 61-1 or Dana 70 (F350) rear axle depending on the application, could have 1310, 1330, 1310/1330 combination or 1350 u-joints.
The 1410 u-joint is only listed for F500's.
Old Dec 18, 2016 | 12:22 PM
Rollingscrapmetal
1310 yoke was cracked anyway
couldnt get a conversion joint
I used a pipe wrench on the yoke to torque it
1310 joint used a 1 5/16 nut the other used a 1.25
usuallybowtie
Jun 6, 2016 12:39 PM
neilc88
May 28, 2008 12:20 PM
92ford150
Nov 3, 2006 07:42 AM
F250FarmBoy
16
Jun 8, 2006 01:11 PM
