Check Engine Light Rough Running
Old Dec 22, 2016 | 01:13 PM
  #31
madpogue's Avatar
madpogue
You may not be able to do the CCT until you get that EOT connector fixed. With a bad connector, the PCM might not ever get a good EOT reading so it might never see the minimum 160F.
Sorry, I don't have the EVTM or the truck nearby, so I couldn't tell you if either of those Standard Motor connectors on RockAuto would be correct.
Old Dec 22, 2016 | 07:58 PM
  #32
bruno2's Avatar
bruno2
The issue turned out to be the IPR. It was bad. I just swapped that one in when I was having a different issue which turned out to be the P/U tube in the rear tank. I took that IPR apart, cleaned it up, and swapped it in when I was diagnosing it. I didn't change the O rings. I just took it apart to clean it.
So I was ignoring it because it was freshly cleaned within the last 8 or nine months. Turns out it went bad. I bought an O ring kit for my spare here locally. The truck is running like a sewing machine now.
Thanks again for your help!
Deb Cablao
15
Nov 4, 2015 12:58 PM
Engalwood
Dec 4, 2014 12:05 PM
Feonix1123
26
Sep 18, 2013 12:46 PM
rednex4u2nv
13
Sep 30, 2010 10:07 AM
hawncase
Jan 8, 2008 07:50 PM
