Check Engine Light Rough Running
Old Dec 21, 2016 | 06:21 PM
madpogue's Avatar
madpogue
Had you warmed it up before trying the CCT? Have you set it up to read the actual EOT value?
Old Dec 21, 2016 | 06:39 PM
bruno2's Avatar
bruno2
Notice how the injection PSI does not fluctuate with RPM.
Old Dec 21, 2016 | 06:42 PM
bruno2's Avatar
bruno2
Old Dec 21, 2016 | 06:48 PM
bruno2's Avatar
bruno2
Here is the HPOP from cold.
Old Dec 21, 2016 | 07:01 PM
madpogue's Avatar
madpogue
Is there any oil in the ICP connector?
Old Dec 21, 2016 | 07:03 PM
bruno2's Avatar
bruno2
I'm not familiar with the acronyms. Explain the CCT as well as how to set up the AE to read the actual EOT?
Old Dec 21, 2016 | 07:07 PM
bruno2's Avatar
bruno2
No the ICP plug was completely dry. I checked that.
Old Dec 21, 2016 | 09:00 PM
madpogue's Avatar
madpogue
I bet if you disconnected the ICP, you'd get the same ^^^^^ thing. That tells me the ICP still isn't working. Could be the new sensor, or the wiring between it and the PCM.
Old Dec 22, 2016 | 08:06 AM
knottyrope's Avatar
knottyrope
IPR could be stuck, what is voltage on IPR checked with a meter? does the volts change with RPM?
Acronyms and Definitions
https://www.ford-trucks.com/forums/1...finitions.html
Old Dec 22, 2016 | 08:12 AM
bruno2's Avatar
bruno2
I am going to clean, put new O rings and then swap in my spare IPR today. I checked the wires at the plug and moved them all around when it was running to see if it would act funny or clear up. I also tapped on the IPR in case it would free the plunger up. I will report back with results.
Old Dec 22, 2016 | 08:14 AM
bruno2's Avatar
bruno2
I will put the meter on it today.
Old Dec 22, 2016 | 08:16 AM
bruno2's Avatar
bruno2
The truck wasn't at operating temp when I did the CCT, but it wasn't a cold start up either. It was probably 110-120 degrees. I will also look into setting up to read the EOT value.
Old Dec 22, 2016 | 08:20 AM
  #28
madpogue's Avatar
madpogue
EOT must be at least 160F for CCT to work.
Old Dec 22, 2016 | 08:47 AM
  #29
bruno2's Avatar
bruno2
The female plug looks like it is broken on the EOT sensor (I think it is the one on the back of the HPOP reservoir?) I am looking into getting another one just in case that was why the EOT codes were coming up at the beginning. I found a couple on Rockauto that look similar to it. Part # HP4400 or possible S612 for the pigtail plug:
More Information for STANDARD MOTOR PRODUCTS HP4400
More Information for STANDARD MOTOR PRODUCTS S612
Old Dec 22, 2016 | 08:48 AM
  #30
bruno2's Avatar
bruno2
I will another CCT when I swap the IPR and run the diagnostics again. This time I will make sure it is up to 160 at least.
