Sponsored by: Real Truck
2003 f250
Old Dec 16, 2016 | 07:08 PM
Tim Vo's Avatar
Tim Vo
2003 f250
Need help changed all my coils and spark plugs, about three months ago and now I have a misfire on cyclinder number six, so I changed that and still lags when stepping on the gas. Does anyone have this problem because my mechanic doesn't know the problem. Help please
Old Dec 16, 2016 | 07:14 PM
seville009's Avatar
seville009
Maybe a plugged catalytic converter. I also had a bad issue with ethanol in the gas in my 2006 F350 5.4l. Mechanic put in some type of heavy duty ethsnol treatment, and I started using OTC ethanol treatment in subsequent fill ups; helped alot. Local gas station sells non-ethanol gas now, so I switched to that.
Old Dec 16, 2016 | 07:53 PM
Tim Vo's Avatar
Tim Vo
You have to pour it in every time you pump gas or is it once in awhile
Old Dec 16, 2016 | 07:54 PM
Tim Vo's Avatar
Tim Vo
Change the fuel filter also but nothing
Old Dec 17, 2016 | 05:57 AM
seville009's Avatar
seville009
I would do it for every full tank of gas, at least until the engine smooths out, then maybe every other tank.
Old Dec 17, 2016 | 06:19 AM
Harryjt's Avatar
Harryjt
my 2001 was lacking power when i bought it. I ended up replacing all of the plugs and coils which helped. cleaned the mass air flow sensor, and replaced both oxygen sensors. what ended up being the ultimate problem was the fuel pressure regulator on the back of the manifold. I replaced that and it was a new truck. my spark knock under load disappeared and the truck will now keeping pulling over 3000 rpm.
hillbilly_1911
Sep 30, 2016 03:00 PM
Preda8or
2004 - 2008 F150
Oct 21, 2007 09:51 PM
dbanghart
Jan 3, 2005 09:19 PM
ACE81
Mar 25, 2004 11:49 AM
bbaamm
Feb 14, 2004 08:30 PM
