Rule of thumb on fasteners?
Stainless is fine for bits you see and worth paying extra. Bear in mind though that corrosion will occur if they interface with untreated carbon steel due to sacrificial protection. More of an issue with any galvanised steel.
Contact with copper should be avoided for same reason. Could that be what you were thinking with anti-seize? i.e. copper based ones.
...Terry
This was decent detail on galling: https://www.boltdepot.com/fastener-i...d-galling.aspx
And Permatex sell stainless steel-specific anti-seize, news to me:
https://www.amazon.com/Permatex-7712.../dp/B0002UENJ2
SS is softer than steel and easily galls as a result. Anti-seize works but it never fails to leave its mark on everything. In order to save myself some time I'll just say that Mylanta/Maalox (or generic equivalent) works as an anti-galling agent for SS, is a lot cheaper and doesn't get all over everything you didn't mean to touch. I'll let you do your own googling to see how it was the only agent approved for A&P service for many years.
Regarding bolt grades, a quick and dirty explanation is to consider the differences between 'soft', 'tough' and 'hard'. Grade 3 being soft, 5 tough and 8 hard. Soft will 'bend' without breaking but will 'stretch'. Grade 8 won't 'stretch' (as much) but will be brittle and break more easily than 3 if 'bent'. 5 is the middle ground - 'tough'.
Nylock nuts are great but I hate using them anywhere they might be exposed to road salts (salt, magnesium chloride, calcium chloride, etc.) Using them in those situations is pretty much signing up for never to be removed without breaking, at least in my experience.
BTW, that white stuff you see on brass fittings is not a sealant. It's an anti-galling agent. If you want/need a sealant don't count on it to do that job.
Regarding bolt grades, a quick and dirty explanation is to consider the differences between 'soft', 'tough' and 'hard'. Grade 3 being soft, 5 tough and 8 hard. Soft will 'bend' without breaking but will 'stretch'. Grade 8 won't 'stretch' (as much) but will be brittle and break more easily than 3 if 'bent'. 5 is the middle ground - 'tough'.....
mellowyellow55
25
03-03-2007 06:07 PM
babyfacejack
20
08-06-2006 10:27 PM
