Code P1121. No power
Old Dec 15, 2016 | 10:15 AM
CopingJohnny8049's Avatar
CopingJohnny8049
Question Code P1121. No power
My 01 Expedition 4.6L 2WD is throwing the code TPS inconsistent with MAF/MAP. i've been told alot of things.. but i havent had a straight answer yet. It's acting like it wants to try, but has 0 power. As in i cannot go up a hill. When I get it to flat land, i can get it going... very slowly. After i get up to about 4500rpm, then it kicks in and i get all of my power back. The TPS was just replaced, and it also has the code for low TPS power/TPS malfunction...
If you Guys have any ideas on what it could possibly be, please let me know.
Old Dec 15, 2016 | 11:00 AM
Skauber's Avatar
Skauber
Did you use a genuine part or aftermarket part when replacing the TPS? Double check all wiring to the TPS to make sure it's good and connected well.
Inspect the MAF for damage, try to unplug it and see if it runs normal. It could also be a vacuum leak between the MAF and throttle body.
Old Dec 15, 2016 | 12:23 PM
CopingJohnny8049
If you consider duralast quality parts, then yes. Haha. And ive tried to find a vacuum leak between the two. I've checked and rechecked all of my connections. and, as far as maf damage, i'm not too sure about that one.
Old Dec 15, 2016 | 12:55 PM
Skauber's Avatar
Skauber
Unplug the MAF and see what happens. That forces the PCM to use default values for airflow, so if the MAF is giving bad values, then it should run fine and have power with the MAF unplugged
99svtlightning2
Escape & Escape Hybrid
Sep 7, 2014 01:27 PM
93Pepe
1983 - 2012 Ranger & B-Series
May 10, 2012 06:50 PM
Mike-11
Jan 10, 2011 11:04 AM
Jackal-73
1997 - 2003 F150
Oct 12, 2009 10:05 PM
lowbed dud
1997 - 2003 F150
Feb 13, 2009 10:03 AM
