lamp out module
Old Aug 26, 2003 | 02:06 AM
brif4i's Avatar
brif4i
lamp out module
I have a 1996 Explorer and need to know where the lamp out module is located. My right front head light (low beam) and fog lights don't work. I heard this is the problem. Can someone tell me where it is located so I can replace it. Thanks
Old Aug 26, 2003 | 06:54 PM
HomerWinzlow's Avatar
HomerWinzlow
lamp out module
Well I wont say it is that module doing the things you are stating, but the module is located under the center console. You can access it from top by removing the message center section and top plate.
Old Aug 26, 2003 | 07:02 PM
brif4i's Avatar
brif4i
lamp out module
THanks I already found it and when it was unpluged the lights came back on.
Old Aug 26, 2003 | 07:04 PM
HomerWinzlow
lamp out module
Good work..
Old Aug 26, 2003 | 07:21 PM
brif4i's Avatar
brif4i
lamp out module
I meant to say that I unpluged it and then plug it back in and it worked. but when I jiggle the wires the lights go on and then off. So now I need to figure out if it is sort somewhere or a bad unit. Thanks again for your help.
Old Aug 26, 2003 | 07:59 PM
HomerWinzlow
lamp out module
Its likely a bad module, which like many devices with a cracked circuit board or bad solder joints can be manipulated to work but probably should be replaced to get the final fix. I believe those modules are fairly reasonable in price.
ryry46d9
Mar 22, 2016 01:47 PM
FordLou
1997 - 2003 F150
Dec 11, 2015 04:36 PM
81-F-150-Explorer
74
Aug 10, 2015 02:23 PM
Rudeman
2004 - 2008 F150
Jun 21, 2015 12:12 AM
MichiganMechanic
Feb 23, 2015 01:12 PM
