No start
Old Dec 14, 2016 | 06:35 PM
Firefighter739's Avatar
Firefighter739
No start
2003 6.0 no start. turn the key to on and nothing happens. dash lights up as it should but I don't hear the glow plugs cycle and no fuel gets into the upper fuel bowl. turn the key over and nothing happens. No starter click nothing. tried the starter wire to the battery trick and it cranks but does not kick over. checked ficm wires and they are secure as well as the injector wire on the intake manifold. it is the original ficm.
Old Dec 14, 2016 | 07:57 PM
BLADE35's Avatar
BLADE35
check fuse F-22
Old Dec 14, 2016 | 08:03 PM
WatsonR's Avatar
WatsonR
The starter wire to the battery only turns the truck over and bypasses the key. It won't start the truck that way unless you turn the key to run and then use the wire.
Old Dec 15, 2016 | 07:16 AM
Firefighter739
Yeah I turned the key on and it tried to crank but to no avail, and thank you I'll check that fuse, is it under the dash or under the hood?
Old Dec 15, 2016 | 09:16 AM
Firefighter739
Update
fuse 22 was blown, replaced it went to start, blew again, happened 3 times while trying to start, where do I go from here?
Old Dec 15, 2016 | 09:49 AM
Per4mance's Avatar
Per4mance
Trace the wire,it's either pinched or rubbed through some place.
Old Dec 15, 2016 | 10:39 AM
Brotherbillstruck's Avatar
Brotherbillstruck
I just read of another issue with wire chafing on the '03's causing the f-22 to blow. Their chaffing was under the turbo.
mcerchio
Jan 7, 2020 08:05 PM
'03-6.0 beast
Apr 17, 2019 09:39 AM
gator1260
Nov 5, 2016 09:15 PM
boulderbronco
6.4L Power Stroke Diesel
22
Nov 1, 2008 12:49 AM
670johndeere
Apr 16, 2007 07:42 PM
