03-6.0 no crank - Ford Truck Enthusiasts Forums
03-6.0 no crank
Old 02-08-2019, 09:52 AM
'03-6.0 beast
'03-6.0 beast is offline
'03-6.0 beast is starting off with a positive reputation.
03-6.0 no crank
I drove to work everything was fine shut it off got ready to go home key with turn over nothing no crank. everything cycles up like it's supposed to power to the starter batteries are good just no crank at a loss!
Old 02-08-2019, 10:13 AM
IHateCommieCars's Avatar
IHateCommieCars
IHateCommieCars is offline
IHateCommieCars has a good reputation on FTE.IHateCommieCars has a good reputation on FTE.
Please confirm - by "no crank" you mean that it turns over but doesn't start, or it doesn't even turn over?
Old 02-08-2019, 10:16 AM
IHateCommieCars
If it doesn't even turn over, the first thing to try is touching the starter wire under the hood to the passenger side battery to eliminate any electrical issue between the key and the starter. You can find that wire next to the passenger fender well towards the firewall. It has a squeeze fitting that separates to give you a bare wire. Might have to free up some slack in the wire to get over to the battery.
Old 02-08-2019, 10:20 AM
'03-6.0 beast
It doesn't turn over everything cycles like normal but nothing happens when you hit the key
Old 02-08-2019, 10:21 AM
bismic's Avatar
bismic
bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Just to add a little to the above good advice:
The starter solenoid wire is a yellow with light blue striped colored wire, adjacent to the passenger side battery in the engine compartment, near the vacuum pump
Also, check fuse F2.22 (fuse 22 under the dash)
Old 02-08-2019, 10:28 AM
'03-6.0 beast
I'll try that when I get back this afternoon
Old 02-08-2019, 10:32 AM
xcrsp440
xcrsp440 is offline
xcrsp440 is gaining momentum as a positive member of FTE.
Check if it is in Park.
Old 02-11-2019, 07:37 AM
'03-6.0 beast
The yellow wire with blue stripe trick worked, she fired right up so where do I go from here?
Old 02-11-2019, 08:43 AM
IHateCommieCars
Lol, you reached the limit of my knowledge; I'm lost on electrical issues. But I know there are past threads here that go through the diagnosis and repair. Good news is your engine is fine. Maybe it's not fully in Park? Or whatever senses that is broke? Fuses or relays?
I'd splice into that wire and run it to an extra battery on the passenger floorboard, lol.
Old 02-11-2019, 10:06 AM
seijirou
seijirou is offline
seijirou is a splendid one to beholdseijirou is a splendid one to beholdseijirou is a splendid one to beholdseijirou is a splendid one to beholdseijirou is a splendid one to beholdseijirou is a splendid one to beholdseijirou is a splendid one to beholdseijirou is a splendid one to behold
See if it will crank in neutral instead of park. If it will, this is caused by loose shift lever that isn't pulling the transmission far enough in park for the neutral safety switch contacts to close and allow it to start. There are 2 bolts up under the dash you can tighten to fix it.
Old 02-11-2019, 03:55 PM
bismic's Avatar
bismic
I would lean more towards an ignition or wiring issue.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
