Question for those who pull bumper-pull trailers...
Old Dec 12, 2016 | 05:06 PM
k7lvo's Avatar
k7lvo
What do you use to lubricate your {(*HITCH*)} ball? Knowing all you-all as I do, please note the emphasis on {(*HITCH*)}. I've heard that placing a layer or two of wax paper between it and the trailer coupler does the trick without making a mess.
Old Dec 12, 2016 | 05:10 PM
Just Strokin's Avatar
Just Strokin
I used wheel bearing grease. I highly doubt wax paper would last long. Never checked into it, but can one get any kind of teflon sheet to use?
Old Dec 12, 2016 | 05:21 PM
69cj's Avatar
69cj
Napa has a ceramic high heat lube for brake pins etc. that I think would work great in that application. Heavy body blue colored so you know exactly how much is applied. I use it for the articulating bushings on my 5th wheel hitch.
Old Dec 12, 2016 | 06:10 PM
CascadeF250's Avatar
CascadeF250
I have always used wheel bearing grease as stated above. I grease both the Coupler in the ball. I also keep the ball cover on when I'm not towing anything.
Old Dec 12, 2016 | 07:46 PM
treatcg's Avatar
treatcg
Reese ball lube
Old Dec 12, 2016 | 07:52 PM
HRTKD's Avatar
HRTKD
I do the same as Cascade250. Grease is critical to my trailer's ability to unhitch from my truck without having to use a crowbar. I slather on so much that I also use a cover to keep in on the ball and off my hands, clothes, etc.
Old Dec 13, 2016 | 01:32 AM
Joneser5000's Avatar
Joneser5000
get yourself a can of white lithium grease. I give a little squirt up the coupler every time and leave the can in the trailer. its not messy if you don't over do it.
Old Dec 13, 2016 | 06:13 AM
suzuki0702's Avatar
suzuki0702
Marine grease 2x a year
Old Dec 13, 2016 | 08:32 AM
k7lvo's Avatar
k7lvo
THanks for the replies. Looks like I was trying to overthink it.
Old Dec 14, 2016 | 06:58 AM
2TrakR's Avatar
2TrakR
WD-40 into the trailer side as needed. My goal is to keep it clean and free of debris. Grease tends to attract dirt and gunk for me.
Old Dec 14, 2016 | 07:51 AM
lynnmor's Avatar
lynnmor
Wheel bearing grease works best for me. I tried white lithium and it turned into a black, dry cake. WD-40 is not much of a lubricant. I also oil the latch parts.
Old Dec 14, 2016 | 08:58 AM
System's Avatar
System
Prolocutor
I did this for a while. The WD40 ended up leaching from the hitch to the ball and down into the ball threads. I got home from a trip with our then 36' TT behind. When I unhooked, I realized that the only thing holding the ball to the hitch head was the last couple threads and the cotter pin that prevented the nut from coming completely off. I still get a pit in my stomach thinking about what almost happened...
Old Dec 14, 2016 | 09:10 AM
U235Fishin''s Avatar
U235Fishin'
I use wheel bearing grease on the ball, the portion of the load leveler tension bars that fit into the hitch, and the two mount points of the sway limiter. When I get set up at my camp site, I remove the hitch from the truck and mount it and lock it in the trailer ball receiver. This keeps the ball clean while wandering dusty roads. Dust and sand in grease is a very good abrasive. Before the first spring trip I clean all lubricated surfaces of old grease and start again.
Old Dec 14, 2016 | 11:37 AM
HDBiker67's Avatar
HDBiker67
Originally Posted by treatcg
Reese ball lube
Same here.
Old Dec 14, 2016 | 11:50 AM
Rod Bensken's Avatar
Rod Bensken
I use synthetic grease. Keep in in a old 35 film canister.
My FIL gave it to me one morning when we we're greasing his combine for the day.
