Edge Insight CTS2 monitoring
These are the PIDS that I monitor on my Edge Insight CTS2. I like boost for fuel economy reasons, EGT's, tranny, oil and coolant temps when towing. The best reasons for the CTS2 in my opinion are that I know when a regen starts and when its over- I don't know why Ford couldn't have given us this info. I also like the capability of being able to force a manual regen.
The only bad thing was my Edge Insight CTS that I had on my 15 SD would not work on my 17 SD. Edge forced me to buy the 2nd edition. I did try Torque Pro back when I had my 15 but it had quite a few bugs in it.
If anyone wants an Edge Insight CTS that will work on the 11-15 diesel send me a PM and we can work out a deal. It would not work on my 16 F150 either so I doubt it would work in a 16 PSD either
Roll and pitch aren't accurate. They don't use the data from the truck but how the device itself is setting. So if you want it to match the truck you need to look in the display and try to set your device so that they match. You might have to angle the front of the display up or down for example.
hth
Mike
I am using the No Limit clean mount. I got it through Alligator Performance on a Black Friday deal.
Edge CTS2 Clean Mount
