Originally posted by 02superstroker i still want your hood
It's pretty nice huh
As far as the length I suppose past a certain point that when the traction bar arcs it won't move the same as the suspension. But I haven't really gotten it to dealing with angles and arcs and all that just yet...........
Originally posted by 02superstroker Ok as far as this goes.. mounting it. If it is six feet long, do i mount it frame to axle six feet while it is at "driving" height?
Yep, you'd want to mount them with the truck parked on level ground with the weight of the truck on the tires. Otherwise I think you'd have a pretty bad bind with the suspension if you mounted them with the axle at full droop.
Hope this helps.
EDIT : Do you off road with the truck??
