Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Air seats
Old Dec 10, 2016 | 09:03 PM
Jckcont's Avatar
Jckcont
Air seats
As anyone installed air ride seats in their 650?
Old Dec 14, 2016 | 08:53 PM
Tenwheeler's Avatar
Tenwheeler
No but I have put them in lots of other trucks. Do you have air brakes or a compressor already? What exactly are you wanting to know?
Old Dec 14, 2016 | 08:57 PM
Jckcont's Avatar
Jckcont
basically I have leaf springs in the front and air bags in the bag so yes I have a compressor onboard. I wanted to see how I could make it somewhat smoother ride. It's a 650 pickup and it never has weight in it and is bumpy which is fine but wanted to know if and how to add air ride seats
Old Dec 15, 2016 | 12:54 PM
Destroked 450's Avatar
Destroked 450
My 94 F-800 has factory air seats, most likely would only came in a truck with air brakes but you can check with a big truck dealer for the seats, finding some that match your interior may be an issue.
Old Dec 15, 2016 | 09:13 PM
NoFrod's Avatar
NoFrod
Ejector Seat ?
I had concurrent main and emergency brake failure in my F-850 one time and an ejector seat seemed appropriate.
Old Dec 15, 2016 | 09:15 PM
Jckcont's Avatar
Jckcont
Originally Posted by NoFrod
I had concurrent main and emergency brake failure in my F-850 one time and an ejector seat seemed appropriate at the time.
I was thinking more of air ride not ejection seats. Then I need to install a sunroof and keep it open all the time!
Old Dec 16, 2016 | 09:39 AM
NoFrod's Avatar
NoFrod
Oh, Darn !
Old Dec 16, 2016 | 08:43 PM
Tenwheeler's Avatar
Tenwheeler
Some of my experiences
1: I have a Bostrom level from the manufacturers rep. in about 1985. It is about a foot long with two bubbles and their name on it. The base should be level in both directions, make it so.
2: From driving a single axle S-model, spring ride and bob tailing back after dropping a trailer. Do not get a low back seat.
3: Like the seat travel to be at about 80-90% toward top where I like to ride. I am 6' but different strokes for different folks. Some air seats only raise rear of cushion and I do not like them. Need to measure pedestal base to steering wheel and compare to seat height. There are some low pedestal seats for buses and such, just not as common.
4: Seats are not always directly behind the steering wheel. May want to put the seat where you like to sit on the bench. Might be to far away from the door arm rest you like or the seat may have it's own and have to be moved over.
5: Lots of options: 1, 2, or no arm rests. Mechanical, air, or no lumbar. Head rests, heat, etc. Some trucks have a bar across the back window to keep the seat back from knocking it out.
6: Looked at a brand X custom 4500. It's air seats look special made due to it's odd mounting pedestal. It also air ride added to the back of the cab for a better ride.
7: Did not catch what year your truck is. If it is fairly new Truck Customs by Chris might be able to help you out if you cannot work it out yourself. Just saying if anyone has custom seats for a late model 650 he would.
Old Dec 16, 2016 | 10:10 PM
Jckcont's Avatar
Jckcont
thank you veryan@ryandeming.com much for all your helpful insight tenwheeler. It's a 2000 f650 pickup and it's new for me. Not trying to be flashy or anything just a nice pickup with a nice ride. Thank you again
Old Dec 17, 2016 | 05:54 PM
Tenwheeler's Avatar
Tenwheeler
You are welcome but please over look the leveling both directions. I thank that's just side because there are adjustments for front to rear.
If you run light all the time lower air pressures may help. Used to see charts for that but not so much so after the Firestone Ford whose at fault deal.
ff1210
Mar 22, 2011 10:29 PM
wmiller
Nov 4, 2010 02:46 PM
conceptcarving
Aftermarket Products
Mar 24, 2010 08:27 AM
hayes041
Apr 10, 2008 09:12 AM
Fordbronco69
Oct 2, 2005 11:19 AM
