Here is a youtube video of it... I took the video down because its no longer relivent..
replaced head gaskets, studs and oil cooler... Crank no start... Any ideas???
Not fixed..... i did fix 1 problem and that turned out to be a bad Ficm!!! New New update not fixed!!!!!! I now have a slow cranking issue.. Page 2 has more info on the new problem..
"You had 99psi ICP before you were even cranking somethings off"...
I started with like 3 psi.. but i forgot to hit record.. so it already had some pressure... when i tryed it again.. but alright i`ll try and see what i get
I could re do the video.. i had forgot to hit record the first time.. thats why you see 99 ICP when the video first starts.. but it normaly reads 3-5 psi before cranking
It sounds like there is a problem with the valve train like a bent push tube or something which is quite common if you didn't have the crankshaft locating dowel in the 6 O'clock position before torqueing the heads down.
well, that seems like my luck... ive been working on this for a month now.. lost my job because i dont have a vehicle to drive..... SmH A 3 day project turns into a Month long circle jerk....
