I usually hang out in the super duty forum, but I would like some input on scheduled maint on a 08 V6 front wheel only.
What is recommended for 100,000 mile maint?
I have noticed kind of a miss when cold, and a small oil leak has recently developed that is not leaving any puddle but I can smell it burning off the exh manifold.
No engine light.
I was planning on plugs. Maybe coil packs (at least the rear bank that is hard to get to)
Is this thing a timing belt? Or chain?
there chains. I would do plug. And the coil boots ,the rubber and spring that coonect the coil to the plug. on the older 3.0 there probably the same though there is upper and lower intake gaskets.PVC valve was under intake to easy to change. https://www.ford-trucks.com/forums/4...ark-plugs.html
