99 3.0
Old Dec 10, 2016 | 10:26 AM
Rogue427's Avatar
Rogue427
99 3.0
I'm looking at a 99 Ranger with the 3.0. Is the 3.0 a good motor?
127,000 miles 4x4 auto. thank you.
Old Dec 10, 2016 | 11:11 AM
TheBigMortboski's Avatar
TheBigMortboski
They are. Not the most powerful thing in the world, but I worked for a Ford dealer for about 6 years and 3.0 Rangers were just in for oil changes.
Old Dec 10, 2016 | 03:51 PM
pawpaw's Avatar
pawpaw
The 3.0L doesn't like to be overheated as the aluminum heads are known to warp & leak coolant.
If it has lots of miles on the engine, valve seat recession is possible causing compression problems.
So maybe consider using a scan tool that can perform a power balance test, to get an idea if further tests like compression testing is wise. The scan tool can also have a look for pending, or set trouble code clues that might me useful in diagnosing possible problems.
If you don't have, or can't come by a scan tool that can do that, maybe consider using your vacuum gauge to follow the test scenarios here, to get an idea of the engine overall health. How to Use and Interpret a Vacuum Gauge
As has been said, if taken care of, it has a good reputation as being a reliable but not a particularly powerful push rod engine, known affectionately as the 3Slow.
More thoughts for consideration, let us know how it goes.
Old Dec 10, 2016 | 04:50 PM
Kruse's Avatar
Kruse
I don't think you'll find too many 3.0 engines with aluminum heads in a '99 Ranger.
OP, a 3.0 '99 Ranger has cast iron heads that are FAR more forgiving than the 3.8/4.2 aluminum-headed engines that Ford used in some trucks. (Just not Rangers)
Getting back on subject, the 3.0 has a very good reliability record. And no, you don't want to overheat any engine.
Old Dec 19, 2016 | 05:54 AM
Rogue427's Avatar
Rogue427
Thanks
Thank you. Most of my Ford stuff is a lot older.
Old Dec 19, 2016 | 04:35 PM
hyspeedz's Avatar
hyspeedz
I have a 2000 Ranger, 3.0, 5 speed, 4wd. It's an excellent truck that gets a lot of use on and off road on the farm. It's not an F150, but it works out great for me. I keep the maintenance going as I've found the better I treat my truck, the better it treats me. The mpg isn't great; I get 18 on average. It's not fast, but will hold its own on the highway. If it's been maintained, with those miles, it's got a lot left in it. I did the cam phaser replacement as it was beginning to "squeak" a bit.
Best wishes!
bigredball90
Dec 20, 2007 04:02 PM
jonboyw
Oct 5, 2006 12:36 PM
dendoyle
Mar 18, 2006 03:46 PM
captain p4
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 4, 2005 03:40 PM
