Modular V10 (6.8l)
2010 V10 heads
Old Dec 10, 2016 | 08:07 AM
Joel Odegaard's Avatar
Joel Odegaard
2010 V10 heads
My motor shop to ride through the block with a hundred grand on it. I bought a new motor from a junkyard that did not require a car the heads that came out this engine are in really good shape. they have any value or should I throw them away?
Old Dec 11, 2016 | 01:11 PM
Sancho's Avatar
Sancho
What happened to the engine? How many miles? What work was needed? I am at 100 k with my 2009,only 1 failed o2 sensor.
Old Dec 11, 2016 | 01:21 PM
Joel Odegaard
the only thing I ever had to do was replaced the catalytic converters. The truck had 128k it tossed a rod out the side of the block. I think we narrowed it down to an electrical glitch and the crank sensor or cam sensor because of a fire I had from some swamp grass I had stuck up in there. But when I pulled the motor apart it looked in excellent condition you could still see cross hatching in the cylinders there are no ridges in the cylinders the Piston slid right out. the camshaft look brand new so I had no problems putting in a used engine with 50k on it but I could not find a rebuilt motor somebody told me there isn't any out there because there's no heads available
Old Dec 11, 2016 | 04:04 PM
Sancho's Avatar
Sancho
I don't know. Maybe someone on this forum, or craiglist?
king-david
Modular V10 (6.8l)
15
Aug 16, 2012 06:42 PM
Fordsflylow
Modular V10 (6.8l)
20
Sep 28, 2008 10:19 PM
desertdave35
1978 - 1996 Big Bronco
Jul 25, 2006 06:52 PM
FrEaKoFnAtUrE
Modular V10 (6.8l)
23
May 22, 2006 06:23 PM
seifertt
Oct 20, 2004 11:41 AM
