Coolant Trouble
Old Dec 6, 2016 | 10:07 AM
MTP55's Avatar
MTP55
Coolant Trouble
What does this look like? Oil in coolant?
Old Dec 6, 2016 | 10:14 AM
timbersteel's Avatar
timbersteel
A neglected coolant system...
Lots of rust....
Old Dec 6, 2016 | 10:16 AM
MTP55's Avatar
MTP55
Is there a fix? Or will it cost hundreds.
Old Dec 6, 2016 | 10:27 AM
78 PEB's Avatar
78 PEB
Start with draining old coolant, then go buy a bottle or two of a good cooling system cleaner. Permatex used to make the best one, but the last time I needed to flush one, I couldn't find it. Don't remember what brand I ended up using. Don't know if Permatex still makes it or not. Use the cleaner as recommended and then refill with new coolant. It will either clean it up or find every place that you would end up with a leak eventually. Looks like the cooling system has been neglected for years on that one!!!
Old Dec 6, 2016 | 10:37 AM
MTP55's Avatar
MTP55
You would be correct. Just want through that process two months ago and problem is back. My cousin owned the truck and was abusive to it and not mechanically inclined. The truck also slowly loses coolant and I haven't fount the leak but it's on something hot because I can smell it. And the oil isnt milky colored. I'm working on getting a loan for a 1993 F350 with a 7.3 idi. 72000 miles. Then I can put this one in the shop as a project.
Old Dec 6, 2016 | 10:50 AM
mrollings53's Avatar
mrollings53
A couple of tablespoons of dawn dish soap works too. Drain the dirty coolant, then refill with plain water. Add three tablespoons of Dawn, and drive around a couple days. Drain the water and repeat if necessary. Once it's nice and clean flush with water until all of the suds are gone. Drain the water and refill with 50/50 coolant/distilled water.
Old Dec 6, 2016 | 05:03 PM
raystankewitz's Avatar
raystankewitz
So, you're supposed to flush until the suds are gone? Is this a single brew, a six-pack or a cold case? I mean, I can kill a sixer pretty quick so that wouldn't be much of a flush. Should you start with a cold case? Just so it flushes for a while?
Sorry, couldn't help myself . . .
Old Dec 6, 2016 | 09:57 PM
Birken Vogt's Avatar
Birken Vogt
My take: drain and refill with 50/50.
Do it again next year if it still looks muddy.
It will be pretty much clean then.
Do it every 3-4 years thereafter to prevent this from happening again.
The cooling system is not like the oil system, doesn't need to be squeaky clean nor can it be.
I don't like using chemical flush, too hard to get it all out and get rid of it. And it seems to make little nuisance leaks pop up all over.
Old Dec 10, 2016 | 05:38 PM
88_F0RD's Avatar
88_F0RD
mine looks like that, and its a brand new radiator, wtf?
I would flush the radiator really good.
there are different ways, I've always used distilled water and white vinegar, its been so long since I had to do this, I forgot the ratio of distilled water to vinegar,
but you drain the radiator fill it with the mix of distilled water and vinegar, let it run, drain it, fill it, run it, drain it, flush, repeat. etc, etc,
Old Dec 10, 2016 | 05:47 PM
MTP55's Avatar
MTP55
Buddy of mine says rust will sometimes come out of the block because it's old and made of iron. Dont know how accurate that is.
Old Dec 11, 2016 | 01:19 PM
mrollings53
I installed a new radiator, water pump, hoses, overflow tank, and thermostat two years ago. I also flushed the coolant several times before refilling with. A couple of months later the coolant was just as muddy as yours is now. I flushed it again a year after I replaced those parts. I'm flushing it again right now, and it's still muddy. I've pulled the drain plugs in the block each time. The driver side plug is full of gunk and doesn't even drain. I'm still getting rust and gunk out of the block after two years. It's not all coming out until I decide to rebuild the motor, and have it hot tanked.
Old Dec 11, 2016 | 01:50 PM
joey2fords's Avatar
joey2fords
judging by the amount of rust in the throat of that rad filler neck, the OP is in a similar state. as for there being a fix ... the rusty insides of the block will continue to discolour your coolant. that in itself is not a real concern, but that rad, and your heater rad, could be awfully close to the point of being ineffective.
Old Dec 11, 2016 | 01:57 PM
timbersteel
As bad as the coolant looks, I would have pulled the t-stat, installed a flush "T" in one of the heater hoses, and used the garden hose to flush the system.
Old Dec 11, 2016 | 03:05 PM
joey2fords's Avatar
joey2fords
i agree; well worth flushing and carrying on ... but i would budget for a rad and/or heater just in case.
jetedwards
Nov 2, 2020 12:25 PM
Dave042
17
Sep 5, 2018 02:02 PM
bismic
Sep 26, 2010 07:10 AM
cheezit
6.7L Power Stroke Diesel
Feb 28, 2010 07:15 PM
Elendil
Apr 2, 2003 03:14 PM
