1988 ford f150 alternator charging ?>
I replaced the alternator on my truck (1988 ford f150) almost a year ago.
the first time it suddenly went out ,and drained my battery
It happened again , and the new alternator came with a new harness. I replaced it, and believe I have it hooked up right.
I re-charged the battery, and let the truck run.
the battery is draining with the truck running.
what do you think?
replace the battery,
or something else?
what do you think?
or something else?
pigtail
I changed the pigtail, does it matter which way the 2 black orange stripe wires are connected to the new pigtail?
I talked to a guy that owns a service station, and he said he always had the parts shop check the new alternator before he would take it.
I took the one I got the other day back, it was tested, and the machine said it was bad.
I got a replacement yesterday, installed today, but the alternator still isnt charging.
I talked to someone who said to check the battery bolt on the side of the alternator, with a volt meter, and see if the alternator is putting out 14 volts,
if not the alternator is bad, or the harness going to the starter solenoid is bad, or the harness coming out of the truck somewhere is bad,
does this truck have a voltage regulator, or is the starter solenoid on this model trucks also the voltage regulator?
google
I googled the service bulletin and didnt find anything...
Is there continuity through the fusible link?
That's surprising.
As mentioned, do you have power to the light green/red wire with the key in 'run'?
Does the charge failure light in the cluster come on when you first turn the key?
(because the lamp is the source of exciter power for the starter)
If no light, check the fuse.
Does this truck have a voltage regulator, or is the starter solenoid on this model trucks also the voltage regulator?
2G's have the voltage regulator attached to the back of them.
Do you see where it says "ground here to test"?
The fender mounted starter relay has nothing to do with regulating the alternator output.
ford
No. They both splice to a single fusible link before attaching to the starter relay.
(Yes there is continuity through the fusible link, to all 3 wires)
That's surprising.
I striped some wiring back, and put a test light lead on the positive battery cable and touched the light green/red wire, with the truck in the run position (not running) and the test light lit up.
That's surprising.
the rear anti lock light lights for a second, and then check engine light comes on for a second, and the brake light is on.
I've checked my fuses in the dash (I will recheck them again). are there any fuses anywhere else?
key on in run
I turned the key on to run,
negative battery post, hooked to test light,
touched the green/red wire with the test light, and it didnt light up.
