Superchip
Old Aug 25, 2003 | 05:53 PM
tbird's Avatar
tbird
Superchip
I just got my 1705 tuner. I pull a 30 ft trailer everyday but under 6000lbs. I was wondering if I want to use the tow safe mode or use the perf tow mode. I did the exhaust and have the gauges, (haven't installed yet). Also if I do the perf tow, is it ok to drive around without a trailer.
Old Aug 26, 2003 | 08:50 AM
FTE Ken's Avatar
FTE Ken
Superchip
Are you asking which modes to use? I can't tell from your post.
Old Aug 26, 2003 | 08:28 PM
tbird's Avatar
tbird
Superchip
correct. Should I use the tow safe mode or the perf tow.
Old Aug 26, 2003 | 08:35 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Superchip
Do you have the two program SCMT, or three? What other mods have you done?
If the truck is stock except for the programmer I'd stick with the low setting. If you've opened up the intake and exhaust you won't have any problems towing with the higher settings.
Old Aug 27, 2003 | 06:52 PM
Michael013's Avatar
Michael013
Superchip
So, if you do not tow you can use the medium setting safely? Or the highest? What about no towing, but a payload in the bed?
Old Aug 27, 2003 | 07:06 PM
tbird's Avatar
tbird
Superchip
I was told not to use the perf tow or highest setting if you haven't done the exhaust or the gauges.
Old Aug 28, 2003 | 10:02 AM
FTE Ken's Avatar
FTE Ken
Superchip
Its pretty much the same as in the manual: low mode, all towing. Middle mode up to 6K lbs. High mode, no towing.
