427 stroker
Old Dec 4, 2016 | 09:41 AM
Brandy4ever's Avatar
Brandy4ever
427 stroker
merry christmas and a happy new year
Old Dec 4, 2016 | 10:37 AM
rla2005's Avatar
rla2005
Woody at fordstrokers is an expert on stroker engines. He is a wealth of information and supplies a quality product.
Even with a mild build of 1 HP per cubic inch you're talking over 400 HP and who knows torque. Every sub-system in the truck will need upgraded. That means fuel pumps and lines, transmission, rear axle, gears, the list goes on.
Any engine from a reputable builder is hard on the wallet. Add in a stroker and the elevated power levels you need to ensure the rest of the truck can handle the power and get it to the ground. I hope you start with a thick wallet.
Old Dec 4, 2016 | 12:01 PM
Conanski's Avatar
Conanski
Originally Posted by Brandy4ever
I have a 6000 pound 1988 f150 xlt lariat with a c6 and a 8.8 rearend 3.55 gearing.
6000lb? How did you manage that? Curb weight for these old 1/2 ton trucks runs from about 4200lb for a reg cab 2wd up to maybe 5000lb max for the extended cab 4x4.
Old Dec 9, 2016 | 02:54 PM
Brandy4ever
427 build
Old Dec 9, 2016 | 03:13 PM
rla2005's Avatar
rla2005
Best bet is to gut the fuel delivery module inside the tank. Fabricate a pick-up and return line to eliminate the low pressure in-tank pump. Keep the fuel level sensor intact.
You can also eliminate the single/dual function reservoir as well. If you have dual tanks then you need some type of fuel tank selector.
Since you are ditching the factory EFI you need to figure out how to trigger the fuel pump on. Perhaps the FI Tech system has that capability.
That 6000 lbs. rating is with the truck fully loaded. I hope your truck mounted camper is lightweight. You will be pushing or exceeding that 6000 lbs. GVW rating very quickly
Old Dec 9, 2016 | 03:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
to mr. conanski...I got that weight number off my registration...6000 gross weight.
The GVWR (Gross Vehicle Weight Rating) is not the weight of the truck!
Ford stated that the Warranty was void if any passengers and cargo exceeded the maximum GVWR which is printed on the Certification Label.
Old Dec 9, 2016 | 03:52 PM
Brandy4ever
427 build
merry christmas and happy new year
Old Dec 9, 2016 | 03:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I may be going out on a limb but I think the warranty on his '88 might have expired. Agree that the gross weight should not be exceeded.
I'm wondering why you stuck with/ rebuilt the 8.8? Was it to keep the abs sensor? When the pinion bearings went bad in my 8.8 (3:55 open) I replaced it with a Currie 9" (4:10 Detroit) since I had long ago gone to 35" tires and it was kind of a dog around town.
Old Dec 9, 2016 | 04:03 PM
rla2005's Avatar
rla2005
to numberdummy....thank you sir,I stand corrected.....what is the weight?....
Post# 3: https://www.ford-trucks.com/forums/1...l#post16767684
Old Dec 9, 2016 | 04:21 PM
NumberDummy
OP has a 1988 F150, the 8.8" was the only rear axle available.
8.8" introduced in 1983, but the 9" was also available in F150/Bronco thru 1986, thru 1987 on E150.
Old Dec 9, 2016 | 04:33 PM
Brandy4ever
427 build
Old Dec 9, 2016 | 07:10 PM
My4Fordtrucks
I realize the 8.8 was the only rear axle available. A 9" from an older model or from the aftermarket is a direct bolt in and is stronger. The truck stops just fine with ABS since it doesn't work all that great to begin with and I also have disk brakes front and rear.
The C6 does not use the sensor for input. That is also the transmission I have in that truck.
Old Dec 9, 2016 | 07:25 PM
Brandy4ever
Old Dec 9, 2016 | 08:18 PM
My4Fordtrucks
Detroit locker and 4:10 gears. It's a little squirrelly on the road in turns since it is in a FSB with 6" lift but I got used to it fairly fast.
You too
Old Dec 9, 2016 | 08:45 PM
Brandy4ever
