Sponsored by: Real Truck
V10 Engine Dies on Cold Start
Old Dec 3, 2016 | 04:43 PM
D.Yaros's Avatar
D.Yaros
2000 F250 SD XLT V10 with 140K on odometer
Now that cold weather has arrived on the initial start in the morning the engine fires right up and runs for a second or two, then dies. It takes 2 or 3 starts before it will continue to run/idle.
I have no idea, and fear, what it will do when really cold temps arrive.
Any clues/hints/idea as to cause of this situation, where I should be looking and what I should do to try and correct this problem?
Thanks for your input. It is appreciated.
Old Dec 3, 2016 | 05:16 PM
Mike189677's Avatar
Mike189677
I think the idle air control valve maybe a good place to start especially if it runs smooth after you get it going. They have a habit of gumming up. Do you notice that when you put it in gear it bogs down and revs it's self back up to normal idle or if you rev it up in park it will do the same thing bog down the rev back to normal idle.
Old Dec 3, 2016 | 05:52 PM
Firefighter 1406's Avatar
Firefighter 1406
X2 on the AIC valve. Had this happen on my dads v-10. Kinda a pain to reach, of course the bolts come out towards the fire wall instead of you being able to see them. And your assembling by feel. Probably an 1hr start to finish by the time you get tools out an such. Not sure if they can be cleaned or not. Someone will chime in if so. Think it was around $60 5 years ago or so when we replaced it.
Old Dec 3, 2016 | 06:50 PM
Mike189677's Avatar
Mike189677
You can clean them I used carb cleaner. Mine wasn't showing any of those symptoms I just did it as preventative maintaince shen I bought the truck.
Old Dec 9, 2016 | 05:08 PM
D.Yaros's Avatar
D.Yaros
Sorry for taking so long to respond. Tx Mike for lead on IAC. Makes a lot of sense to me. As it is cold outdoors, not likely I shall be turning any wrenches on the engine for a while, but I shall put the advice in my memory bank, and on my "to do" list.
I would add that I decided to try turning the key on and waiting a second or two before cranking the starter. So far that seems to help: The engine fires up and stays running instead of dieing; at fast idle for a short period, than drops down to normal idle.
Old Dec 10, 2016 | 10:07 AM
ashleyroachclip's Avatar
ashleyroachclip
Might check fuel pressure .
my72ford
Feb 25, 2019 09:27 PM
67 FE Fan
Mar 27, 2017 06:58 PM
EXv10
Modular V10 (6.8l)
32
Dec 29, 2013 10:34 AM
perryg114
Modular V10 (6.8l)
13
Aug 9, 2010 10:09 AM
MagKarl
Dec 30, 2008 01:00 PM
