OBS F250 Progression Thread
Old Feb 23, 2017 | 10:37 PM
larry_fopps's Avatar
larry_fopps
Changed the cap, rotor, coil, and wires tonight after work. Went with the 9mm Ford racing wires. Sometime in next week or so, i'll replace the spark plugs.
Old Feb 24, 2017 | 06:00 PM
Red97350's Avatar
Red97350
I would start soaking the plugs now so they should come out easier.
Red
Old Feb 27, 2017 | 04:34 PM
larry_fopps
Red
Oh yeah, i've been soaking them in PB a few separate occasions over the past two weeks. They look awfully crusty, so hopefully i don't have any issues.
Old Mar 21, 2017 | 11:17 PM
larry_fopps
After numerous soaks of PB blaster, tonight i tackled the spark plugs. Luckily these crusty *******s all came out without problem.
Old Mar 23, 2017 | 08:43 AM
larry_fopps
Also two weeks ago, I put in a brand new starter. Starter and complete tune up done at 99,000 miles and change.
Old Mar 28, 2017 | 02:37 PM
larry_fopps
Had to pull my cluster apart again last night. The voltage gauge in the cluster with the odometer that I swapped into the truck was bad, so i took the gauge motor from my original cluster. Also the glue on the faces on both temp/oil pressure and voltage/fuel gauges, let loose, so i just set those back in place and hit them with a couple dabs of plastic weld action. Good as new. Replaced the trim piece around the cluster as well, as a previous owner once just ripped it off and broke it, so it had a few cracks in it.
Old Mar 28, 2017 | 07:17 PM
'89F2urd's Avatar
'89F2urd
I'm late to the party, good thing that guy called you back....looks like an awesome truck.
Old Jun 7, 2017 | 10:52 AM
larry_fopps
It is indeed. Thinking about offering it up for trade though. I really want an extended cab Long Bed Powerstroke.
Old Jun 19, 2017 | 11:04 PM
larry_fopps
On Friday I rolled 100,000 miles.
I took the week off of work to get caught up on a million outstanding projects. Today, I replaced the fuel filter, some vacuum lines, replaced the support brackets for the passenger side running board, and repaired the trans pan to frame ground strap. Also found a power steering leak. It seems like its coming from the cooler hard line, but i'm not sure if its coming from up higher. I need to get a closer look tomorrow. I wish I replaced the fuel filter and went over vac lines sooner. Its like a different truck. It actually gets out of its own way now.
Old Jun 20, 2017 | 04:59 AM
'89F2urd's Avatar
'89F2urd
You can bump the timing which will yield a little "crispier" of a throttle pedal to top off your tune up.
Old Jun 20, 2017 | 07:24 AM
larry_fopps
i've thought about that. Any idea how far I can advance and it still be safe?
Old Jun 20, 2017 | 08:21 AM
'89F2urd's Avatar
'89F2urd
The typical suggestions are 12-14. There are a lot of variables that dictate how much timing an engine will tolerate - engine wear, elevation, fuel quality, combustion chamber efficiency, accuracy of timing marks, etc....if you know how to listen for ping, you can advance it until it pings then back off a degree or 2. That's how I always time my stuff, at least anything with these old inefficient combustion chambers.
Old Jun 22, 2017 | 10:12 PM
  #28
larry_fopps
Got it. Thank you. I do know how to listen for ping, so i'll bump it up eventually when I get some time. Immediatly after doing the fuel filter and vacuum lines, I got a power steering leak. I'm not sure if its coming from the power steering cooler hardline, or if its coming from above that, I really can't tell, something else to worry about at another time. I think before this winter, I need to go over the entire cooling system.
Old Jun 22, 2017 | 10:16 PM
  #29
larry_fopps
Also, I put a backrack on it. For two reasons, one, I moved a friend recently, and had a couple close calls breaking that rear slider. Also me and the woman have 10'6" stand up paddleboards that i'd like to be able to move around a little bit easier. Now i'm looking for a lowp rofile diamond plate toolbox.
Old Nov 9, 2017 | 10:47 AM
  #30
larry_fopps
I haven't updated in a while, but i've done some things recently.
Original speakers replaced with Kickers.
I just got some fresh paint on the frame.
Realized that my transfer case isn't shifting into neutral or 4lo. The linkage is probably seized, going to check that out tonight. This weekend hoping to get an interior and exterior detail pre - winter. I've got husky liners on the way, next thing is a tool box for the bed.
