FORScan and As-Built Data
#31
I apologize, I did not up load the ab file last night. With the VIN the Larry found, I d/l the ab file. I was in such a hurry to start comparing files that I forgt to up load them.
I did make a change to my settings last night. I am close to a regen and felt I had to do something... anything... even if it was wrong!
So I took a wild swing...
These are the settings for my truck currently:
720-01-01 EA21 BA83 EF60, disable DPF screen
720-01-01 EA21 BA83 FF70, enable DPF screen
This is the setting from the truck that Larry found:
720-01-01 EA21 BA82 7FEF, enable DPF screen with compass direction letter on info center screen
I am currently sitting at 80% on my DPF... and no "Hold OK to Clean" message... yet.
Edit: I made my settings match the truck settings that Larry found.
Mike
#32
I will plug those into mine as well. I'm at 90%.
Also no was to back up all modules at once that I found. I did find it easier to screenshot. (Snipping tool) my module values for quick reference. I would split the screen and have the photo on one side and FORScan on the other
I also agree with Larry. If you have you original as build data from Ford you always have the values available for reference.
I have not had the issue you are describing.
Keith
Keith
#33
Also for whatever reason, I cannot get the DRL to work in any of the configurations. If I enable the low beam then go into BdyCM Module configuration (NOT AS BUILT format) it shows DRL enabled and DRL type as low beam but the lights do not turn on. If I select fog or turn signals in AS BUILT I get "error" for both DRL and DRL Type in the BdyCM Module. Ideas?
Bob
#34
Backup isn't really the total issue and yes I can use notepad to document changes.
My problem is that I can't save/write the nav changes. I can make the change but when I go to save/write it I get the same error. BUT I enabled "dark car", since mine is black and it saved those changes fine.
#36
I changed the NAV override setting on my truck and my Travel Link (weather, traffic, etc) disappeared. Not a major deal for me since I currently don't have a subscription to any of the services. Anyone else have this issue?
Bob
Bob
Your DRL turn on when you place the truck in gear.
Hth
Mike
#38
Thanks for the help.
Bob
#39
Glad you got it going
Keith
#40
OCR Option
So I needed some quiet time after a couple hectic days at the office.
Went over some notes and old posts.
Just Strokin (Larry) Larry posted up the first info on how to enable DPF % screen using IDS. IDS - DPF % Screen
If you notice in the 2nd photo is says Diesel Particulate Filter Cleaning (PCM) - Not Equipped.
Larry comments in a later post that he did not notice any change so he left it Not Equipped. I will go back in my IDS and check / Change mine and recheck As Built data for any changes. But being it is noted in the PCM we may not be able to see it (yet)...
I am comparing the AB data to the one posted that has OCR enabled.
Thanks
Keith
Thanks
Keith
#41
You're correct! The travel Link does disappear when the NAV Override is set. Thank you for noticing! When the NAV is returned to the Factory setting, the Travel Link returns. For the mean time, I will make a note on the origin post so everyone is aware.
Thanks again,
Mike
#42
I'm assuming that you enabled "Dark Car" at a different time than the NAV changes. Is your Extended License still Valid? I had a similar problem when mine expired.
Mike
#43
#44
Mike
Mike
Note: My truck ran fine and did not notice anything different about it.
The DTC that I have is;
Code: U045A
- Invalid Data Received From Parking Assist Control Module A.
Additional Fault System:
-Invalid/Incompatible Configuration
Module: Instrument Panel Control Module.
Mike
#45
Thanks
Keith
Thanks
Keith
If OCR can be turned on in IDS, we should be able to reverse engineer the settings and transfer to FORScan. me know if you need me to do done comparisons also.
Edit: Keith, if you need help comparing files I can help.
