New warning messages...sometimes
now, within the past few weeks, I've been getting 2 warning messages at random times (sometimes at initial startup, sometimes driving down the road).
service advance-trac
hill decent controll fault
sometimes when the errors appear, they only stay a minute or so, sometimes, until the truck is restarted.
in the previous problem, the dealership saw NO CODES in the computer, but was able to duplicate the problem (I did notice that the park brake bracket no longer has the junction box attached to it
)anyone else have this issue with error messages & what was done to remedy the situation? I'd prefer to give the service department some hints instead of waiting 3 days for them to even figure out what is wrong with it.
?? is it covered under the 100,000 mile powertrain warranty?? I am asking because other threads I've read say its been an electrical problem.
allcool's Avatar
allcool
allcool is offline
allcool is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Ndawg12 View Post
I'm also having the same problems: Hill Decent Control Fault and Service AdvanceTrac. I have not had any starting issues and have not been on slippery roads or offroad yet. The only annoyance so far is pressing OK twice at each startup to clear the messages. But with winter approaching I need to get this fixed. This is a 2015 F250 DSL with 32,000 miles.
This is a common problem.
With a very simple fix.
A large wire harness plug located on the emergency brake bracket is lose/not making good contact. This large plug/connection feeds the ign switch, etc...
The fix is too Unplug and re-plug firmly. Some have relocated the plug off the e brake bracket and wire tied it away from the bracket.
I was having this same problem almost daily. For me it started with a little chime while driving then the error message pops up.
My fix was to just unplug that big connector on the e brake bracket, checked all pins to make sure they were not bent or backing out and re plugged in firmly.
Never had the problem again and its been about year now since my last
'Hill Decent Control Fault and Service AdvanceTrac' message. If you do a search there are many threads on this on many SD forums.
Some get even more error messages along with the above. Some can't start up if the connection is intermittently totally open on certain pins. Problem is all in that connector/plug.
Hope this helps....
__________________
2014 Platinum ingot silver F350 srw ccsb, Bilstein 5100, Bedrug, ReTrax One Tonneau Cover, KC HiLiTES 70w HID spot beam driving lites, 55w Morimoto Mini D2S HID projectors with led DRL & led amber turn signal inside shroud halo, Husky X-act Contour floor mats, HUSKY rear wheel well liners, NuShield NU380A, + a few other things...
I had to have it towed to the dealer. They were baffled but called Ford and were told that it was "a couple of computers unable to talk to one another" and were advised to hardwire past 2 (I think) connectors. I just got it back but it appears to be fine.
This is a lightly used 2015 with 7500 miles on it.
in that case, it was some bad splices in the factory wiring harnesses, in this most recent case, it was the connection at the "plug". the dealership ended up wiring past the plug & there are no problems "at this time"
It's kind of like buying a new truck, and one of the brake lines is bad so they "fix" it by unplugging and cspping that brake line because the other three brskes can do the work. It just ain't right.......
