59 4x4 conversion
Old Nov 27, 2016 | 07:47 PM
F100freak80751's Avatar
F100freak80751
59 4x4 conversion
I am taking this...
Old Nov 27, 2016 | 07:49 PM
F100freak80751
and putting it on the frame from this...
Old Nov 28, 2016 | 01:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1957/60 short bed has a 110" wheelbase, 1973/79 short bed has a 117" wheelbase.
Old Nov 28, 2016 | 06:30 PM
GeeeMCeee's Avatar
GeeeMCeee
Worked for me
Old Nov 28, 2016 | 06:32 PM
GeeeMCeee's Avatar
GeeeMCeee
Actually PO did it and rear axle was moved.
Old Jan 1, 2017 | 08:13 PM
F100freak80751
Originally Posted by GeeeMCeee
Worked for me
How much lift did you put under that? Looks great that high..
I am going to shorten the frame after we get the cab lined up, and we are looking at around a 6" lift and 35" tires. That's if 6" is enough. May have to run a little bit of a body lift also.
Old Jan 5, 2017 | 09:34 PM
GeeeMCeee's Avatar
GeeeMCeee
F100 if you look in my pictures you can see the way the PO lifted the body, there was no pic of the rear cab supports, they were also 2" pipe, I think about 7" long and leaning badly. Take a look at the springs, the fronts were a homemade brew of 9 or 10 leaves and the rear had 13 leaves. I think when it was all done we dropped it 2-1/2 to 3".
Old Jan 5, 2017 | 10:46 PM
F100freak80751
Out of curiosity, what size tires are on that in that pic?
Old Jan 6, 2017 | 09:09 AM
willowbilly3's Avatar
willowbilly3
Well, lift it right if you do. There are a lot of parts to buy to make one of those right. Most of the lifted ones I've seen, they didn't tend to the track bar and tie rod angles well enough and they end up being a bump steering death trap. You'll notice the track bar and and tie rods are pretty much parallel with the ground. If you don't maintain that, it will bump steer. I'm not sure if anyone makes a 6 inch drop pitman arm, I have seen them and it looks pretty janky. The track bar mount is pretty easy to fab. Also radius arm rear mounts need moved down, just adding longer springs throws out the caster or king pin inclination.
Old Jan 6, 2017 | 09:41 PM
GeeeMCeee's Avatar
GeeeMCeee
Original tires were 12x16.5. Current tires are 255 85 r16
johnfin1
Apr 22, 2019 11:26 AM
lightninquick
Jan 29, 2017 11:11 PM
benbuilder
Ford Truck Parts for Sale
Jan 5, 2015 02:26 PM
lvin4jc
Apr 23, 2011 07:16 PM
catan70
Mar 6, 2008 09:49 PM
