Sponsored by: Real Truck
Starter issue I think.
Old Nov 27, 2016 | 02:37 PM
APEXDUCK's Avatar
APEXDUCK
Ok I have a 99 f250sd v10 with 180k miles. Original owner and have most work my self over the years. Son took the truck to fill it up, started fine ,filled it up and now will not start. It has power but will not crank. Trys to but no good. I was thinking battery died. New battery same results. Sort of tried to start but not turning over. With the new battery i tried several times then nothing. No power at all. No lights, nothing. So I put the old battery back in and still no power at all. I'm thinking the starter is toast and my repeated attempts to start that I pulled too many amps and blew a master fuse? It stilling in a parking lot until tonight when I can tow it home.
Thanks for any thoughts on where to start.
Apexduck
Old Nov 27, 2016 | 04:47 PM
Chuck's First Ford's Avatar
Chuck's First Ford
recharge the battery and have it tested ( BOTH )... remove starter and have it tested..
but with 180K ,, starter might be toast.
Old Nov 27, 2016 | 07:40 PM
Sam I Am's Avatar
Sam I Am
"No power at all. No lights, nothing." = bad connection on a battery cable or main ground wire.
Wiggle and inspect cables until you find one loose or corroded. Will probably be more than one at that age and mileage.
Old Nov 27, 2016 | 09:35 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yeah X2, if there's nothing visibly corroded makes me think fusible links maybe ?
Old Nov 28, 2016 | 11:46 AM
APEXDUCK's Avatar
APEXDUCK
Thanks for all the advise folks.
Well the good news is the battery was good. Connection a little loose and corroded. Took the starter off and had it tested. Bad sellonoid but only had full starters to replace it. So I installed the new starter. Everything back in place tightened and secure.
Bad news.... no joy. Same symptom as before. Good power but starter will not turn engine. Looks like the engine is ceased up. It had been making a rattle noise off and on from the front of the engine so I was thinking the bearing on the water pump was going out. Looks to be more serious. front main bearing? Far beyond my skills and knowledge.
I can't image off hand how bad a V10 rebuild will cost me. Bad day getting worst.
Anyone know a quality mechanic I Apex NC area?
Apexduck
Old Nov 29, 2016 | 10:52 PM
jetjockey99's Avatar
jetjockey99
Before condemning the engine pull the serpentine belt off and try it, seized A/C compressors have been known to give the same symptoms and that could have been your rattling noise also.
Old Dec 1, 2016 | 09:24 PM
APEXDUCK's Avatar
APEXDUCK
Thanks for the tip. Yes the AC has been out for some time so the compressor is very possibly the culprit. I will test tomorrow. I would not think that the serpentine belt would freeze the engine but your assessment fits the symptom.
Apexduck
Old Dec 2, 2016 | 05:29 PM
APEXDUCK's Avatar
APEXDUCK
Jetjocky99 hit the nail on the head. Seized AC compressor was keeping the engine from turning over. Thanks for saving a lot of time and money.
Apexduck
Old Dec 3, 2016 | 12:47 AM
99f350sd's Avatar
99f350sd
There we go. Good job JJ.
Old Dec 3, 2016 | 10:52 AM
SnowPlowDriver's Avatar
SnowPlowDriver
I believe someone makes a kit to eliminate the ac compressor and add a pulley to replace it. May be an option on an older truck if you can do without the ac.
blue76
Jul 1, 2016 07:23 PM
williambaker
Aerostar
13
Sep 30, 2013 02:04 PM
dan1101
Aug 19, 2006 01:14 PM
MustangGT221
Jan 24, 2005 07:11 PM
cnolin
Oct 2, 2003 05:49 PM
