Bed rust questions
Old Nov 26, 2016 | 05:05 PM
Anderson80's Avatar
Anderson80
Bed rust questions
Found some rust on the bed floor and was wondering if a body guy could repair it to stock?
Old Nov 26, 2016 | 05:17 PM
redcreekauto's Avatar
redcreekauto
Yes it can be done relatively easy enough for a properly equipped body man.
Old Nov 26, 2016 | 07:16 PM
HIO Silver's Avatar
HIO Silver
Concur. Fixable.
... ask the body guy to install/create drain holes too.
Old Jan 3, 2017 | 01:05 AM
67f10071f250's Avatar
67f10071f250
Easy fix for a body guy.
For the rest of the bed, if you haven't heard of these products, chk them out. I use them on both my old trucks.
Some Metal Blast, Rustmort would kill the rest of your rust. Maybe use some Por 15 paint then bed liner.
It'll out live most anyone reading this.
Old Jan 3, 2017 | 01:41 AM
gijazbo's Avatar
gijazbo
LMC and tabco sell bed patch panels for a reasonable price. Your local guy could use them in lieu of creating his own patch panels to save on shop hours. (The small panel is like 23 bucks)
To be honest I would cut out the cancer yourself for free and just buy the patch panel. It wouldn't take a good body guy but an hour to weld them up nice.
Old Jan 3, 2017 | 05:33 AM
vtpkrat2's Avatar
vtpkrat2
Keep in mind that is all you are seeing from this side. Here in the northeast the rust would probably be extensive on the underneath/backside. What you would see in the picture is just where the rust decided to rear its ugly head and come popping through. I would guess around your rust holes it is pretty solid so ,yes,it can be easily repaired. A couple hundred dollars would do it in my shop. Just a general idea for you. Good luck! gary
Old Jan 3, 2017 | 08:30 AM
78 PEB's Avatar
78 PEB
vtpkrat2......Interesting take on rust on a bed floor......In our part of the world......the way you would rust thru a bed floor is due to crap (generally hay, old leaves etc.)being held in the bed with no way to drain. I realize you guys salt the hell out of the roads up there and they are starting to use a lot of chemical de-icers around here anymore so its a good thing for us to start keeping in mind........I know that since they have started using so much of that crap......it is hell to keep all the lights working on a semi truck and trailers.......one small spot of exposed copper wire and the **** will eat thru the wire in a day.......been there done it many times.
Tonto Kowalski
Virginia Chapter
Jul 30, 2018 10:06 AM
spencer922
Ford Truck Parts for Sale
Dec 30, 2017 05:38 PM
ghunt
Paint & Bodywork
Sep 23, 2015 07:23 AM
berry1234
Paint & Bodywork
18
Jul 28, 2011 12:41 PM
SNSTER
38
Dec 13, 2009 08:57 AM
