6.9 tach died
Old Nov 25, 2016 | 06:40 PM
SpencerS's Avatar
SpencerS
6.9 tach died
My tachometer has no reading at all, it might have happened after I was trying to find a blown fuse and was pulling them out, while the truck was running. I have switched out both the tach itself and the pickup sensor on the injection pump. I also followed the wires from the sensor to the firewall and they look fine. Any suggestions?
Old Nov 25, 2016 | 07:06 PM
Franklin2's Avatar
Franklin2
Are your fuel and other gauges working? The one diagram I looked at showed the tach powered by the same supply as the other gauges.
Old Nov 25, 2016 | 07:20 PM
SpencerS's Avatar
SpencerS
Yep, they all work. Even the background lights still work
Old Nov 27, 2016 | 05:50 PM
Gary Lewis's Avatar
Gary Lewis
Wiring diagram is show on Page 98 here: Fuel Tank Selector & Gauges - ???Gary's Garagemahal. And I don't see much of anything involved but the engine speed sensor, wiring, the connector to the gauges, and the tach itself. However, power is supplied by Circuit 640, which is shown on the left end of the fuse block on Page 22 here: Charge & Power Distribution - Diesel Engines - ???Gary's Garagemahal.
Old Nov 28, 2016 | 06:44 PM
SpencerS's Avatar
SpencerS
Appreciate the links. On them it shows that the 640 wire also has to do with the seatbelt buzzer, which I noticed has also stopped working, so maybe I messed up the fuse box just for that area? Or somehow the fuse is bad, but looks fine?
Old Nov 28, 2016 | 06:47 PM
Gary Lewis's Avatar
Gary Lewis
Fuses can easily be bad but look fine. I'd start with that.
Old Nov 29, 2016 | 03:55 AM
SpencerS's Avatar
SpencerS
So I changed out fuse 18 and it did the trick, and then about 10min later the tach started being all erratic. Could this be the voltage regulator for the instrument cluster? And is that what I'm pointing to in this pic?
I'm pointing with my pointer finger lol
Old Nov 29, 2016 | 04:30 AM
Ford F834's Avatar
Ford F834
The ICVR does not affect tach function. Since the issue started by messing with the fuse block, I would check there for a bad connection or corroded contact etc.,
Old Nov 29, 2016 | 07:28 AM
Gary Lewis's Avatar
Gary Lewis
Amen. That is the ICVR and you can see that it only supplies power to the water temp, fuel, and oil pressure gauges here: Fuel Tank Selector & Gauges - ???Gary's Garagemahal.
Old Nov 29, 2016 | 11:16 AM
SpencerS's Avatar
SpencerS
Today after school I'll detach the fuse box from the firewall and take a look behind it to make sure everything is plugged in. Any tips? Also, I don't know if it makes a difference, but the tach only gets all weird when the truck is warmed up. I drove it this morning and the tach was fine, but once warm started bouncing.
Old Nov 29, 2016 | 03:15 PM
1986F150six's Avatar
1986F150six
SpencerS, open this link [from the forum stickies] and read. It might be of assistance.
https://www.ford-trucks.com/forums/7...dywhompus.html
Old Nov 29, 2016 | 04:32 PM
SpencerS's Avatar
SpencerS
It's been awhile since I read that thread. I'll have to take the cluster out to see if it has the brown stuff. In the meantime, I took apart a spare 6.9 tach, but after looking at it and the thread, it seems to be the "new" style? If so, I guess I could see if it will work.
I don't exactly know how similar the diesel and gas tachs are, but it has the same circuit board as the gas tach in the linked thread
Old Nov 30, 2016 | 03:17 AM
SpencerS's Avatar
SpencerS
Well, that tach did the same thing. I'll still try to clean my original. Then I'll check out the fuse box, still not 100% sure how to do that though
Old Nov 30, 2016 | 05:53 AM
Franklin2's Avatar
Franklin2
I would swap your old sensor back in that reads the gear on the engine.
Old Nov 30, 2016 | 02:47 PM
SpencerS's Avatar
SpencerS
Swapped the original sensor back in and drove around a bit with the spare tach, and it worked longer than it used to. Put the original cluster back in and drove some more, even going on the freeway and the tach read correctly the whole time. Not sure what happened, but I'll check back after a week of driving to see if the tach keeps working. Here's a pic, hope you guys like my setup. Got real lucky and found a diesel rosewood AC bezel for $120
Also: THANK YOU ALL. you guys are awesome
