ENABLE Hill Decent Control in 4x4 via FORScan
For those interested:
Today I successfully added Hill Descent Control to my nephew's 2015 F350 4x4 that normally comes with the Fx4. I added the combo Hill Descent/Traction control switch and found the changes needed to the ABS "As Built" module via FORScan and enabled it without any DTC's
Part # Needed:
SW-6777 Switch, Motorcraft
or
BC3Z-13D730-AA Switch, Ford
The switch is about $32.53 from tascaparts.com
ABS "As Built" Module:
760-01-01 xxxx xxxx 3xCx Hill Descent Control enabled
760-01-01 xxxx xxxx 2xBx Hill Descent Control disabled
disclaimer:
Make changes at your own risk. Always make a back up of your "As Built" data just in case you need to revert to factory settings.
Edit: Fixed Descent spelling
Part # Needed:
or
disclaimer:
You have to start out SLOW and it doesn't work above a ridiculously slow speed. I'd have to double check but it's something like 5 mph... I only used it once to help me not go off the side of a mountain while going down my daughter's friends 45 degree, snow/ice covered driveway. I actually slide backwards down it trying to go up it. Needed 4WD LOW to make it up. It's so steep that there are switchbacks in her driveway.
I am trying to do this to my 2013 f350 ccsb lariat 6.7 with trailer brake controller, my current line code is 760-01-01 9C3C 3600 29A0 and I have tried changing it to 9C3Z 3600 39B0, the truck takes it but the feature still does not work, is there something I am doing wrong? When I put the code in all I change is the 2 to a 3 and then forscan changes the A to a B. Thanks for the help.
Lucas2009, I replied to your post in the "FORScan and As-Built Data" thread.
I will come back and edit this post if your issue is resolved in the "FORScan and As-Built Data" thread.
Mike
Wiring Needed
Great post! I am new to my 2015 F350 King Ranch, New to Fords in general, New to Forscan. Excited to start trying some of these mods myself. I found the switch on Tasha parts and still learning how to use FORSCAN--but do I also need a wiring harness or is the wire already there? DO you have any pictures or videos to install the switch. Thanks in advance!
I did not do any instructions or videos. There are a lot of videos on YouTube that show how to remove the center dash panel so you can swap out the switch.
HTH
When testing HDC operation be sure that the truck is running for the HDC switch to work.
Maybe I'll check some calibration codes and part numbers.
Not sure if what you are asking. One the switch is installed you make the changes using ForScan. That's it.
