Sponsored by: Real Truck
Winter bed weight
Old Nov 23, 2016 | 03:41 PM
acf6's Avatar
acf6
Winter bed weight
Does anyone run weight in their bed during the winter? With my crew cab long bed, even with brand new toyo MTs, i dont have much traction in 2wd...and i dont feel like driving around in 4x4 all the time if its snowing. I think because there is hardly any weight on the rear axle with the truck being so long.
I was planning on just buying some sand bags that hopefully can be reused, but was wondering what weight people run. 500lb seem like enough?
Old Nov 23, 2016 | 04:21 PM
sxrfun's Avatar
sxrfun
You have a 4x4 but you don't want to use it? lol......I don't put any weight in mine...but I use the 4x4 option......I've heard of others putting 5 0r 6 bags of softener salt in the back....they are 88 lbs for the bigger bags, so that would give ya in the area of 500 lbs give or take...so yeah should be enough.
Old Nov 23, 2016 | 04:23 PM
acf6's Avatar
acf6
Its annoying if there is 1" of snow. I only need it to get going from a stop, then im fine. Id rather just put some weight in my bed and actually be able to navigate around. If im driving in a major snow storm then yeah im in 4x4 the whole time. Even in 4x4, with an open front end, its not overly useful when im up in vermont. If i have my snowmobile (about 600lbs) in the bed, then im fine...so just wondering is 500 is still a useful amount.
Old Nov 23, 2016 | 04:29 PM
sxrfun's Avatar
sxrfun
I hear ya.....I'm just to lazy to put the weight in and out......the salt can be used in the spring if ya have a softener at home as well.
Old Nov 23, 2016 | 04:31 PM
acf6's Avatar
acf6
I do not. I have manually locking hubs so i dont always drive around with them locked, just if i know theres going to be a big storm or im going to be offroad
Old Nov 23, 2016 | 04:44 PM
seville009's Avatar
seville009
I put about five 80lb tubes of sand in my F350 daily driver; definitely helps. In my F350 plow truck, I have eleven tubes plus about 300 lb of stuff.
Old Nov 23, 2016 | 05:14 PM
xr7gt390's Avatar
xr7gt390
I don't put any weight in mine, but it could probably use some. I do use the electronic locking rear end more than I use 4x4. It seems locking the rear end give me good enough traction to be the first person away from the light.
Old Nov 23, 2016 | 05:30 PM
mark224's Avatar
mark224
I've never needed weight in any truck I've owned , I go by the make it walk don't talk rule. In other words soft on the gas at the corner, but the tube sand will give you enough. Make sure you put it over the axle to get the most out of it. Plus if you need to you can get out and put some of the sand under the tire to get traction.
Old Nov 23, 2016 | 05:32 PM
acf6's Avatar
acf6
I certainly dont "need" any weight with 4x4...but i dont see the point in driving around in 4x4 everywhere. Id rather just add some necessary traction to the rear end of an empty truck bed. My plow truck is a crew cab short bed and with some bags of ice melt and other tools, it does ok...but my truck is pretty bad
Old Nov 23, 2016 | 05:42 PM
163junk's Avatar
163junk
I have a 4x8 sheet of 1/4'' diamond plate for mine, my buddy has 2 sheets of 1/2'' plate 2x6.5 in his short bed. Heavy to move twice a year but works.
Old Nov 23, 2016 | 07:04 PM
ligito's Avatar
ligito
Add the weight and be happy.
Works with 2WD, too.
Old Nov 23, 2016 | 07:17 PM
Misky6.0's Avatar
Misky6.0
I've got a steep 12% gravel driveway. Every SUV/minivan vehicle can make it in 2wd, but our F350 SC long bed requires 4wd, when empty. Even with limited slip rear both rear tires spin and the rear end hops up and down. Stop, put in 4wd problem solved.
Old Nov 24, 2016 | 08:09 PM
FordBlueHeart's Avatar
FordBlueHeart
I've got 8-10 48# bags of play sand in 5 gallon buckets in my bed. This is the first time I have put weight in the bed. I did it originally to overcome the leafspring hop due to worn out shocks. It's only snowed a couple inches last week, but it definitely made it easier to drive in 2wd.
Old Nov 25, 2016 | 05:37 AM
don123's Avatar
don123
I'm carrying about 600 lbs in tools and a 200lb ARE truck cap and that works great for plowing. 500lbs will definitely help. I put 2- 4'x8'x5/8" sheets of plywood on top of my tools and secure everything with heavy duty ratcheting straps. I know a guy who put a bunch of sand bags close to his tailgate without securing them. Then when he smashed into a tree at 45mph the sand bags went right through his back window and killed him. Make sure you secure whatever you put in the back!
Old Nov 25, 2016 | 06:45 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I use an OLD bar-bell weight lifting set.. cast iron... about 600 pounds.
I have 2 wheel drive. second truck. but been using weight lifting set in station wagons since the 1970's....
who need 4x4 on pavement.. drive like you have an un-cooked egg under your foot. and weight in the back, and behind the rear axle.
I truly enjoy the E-Locker rear end. but several of my old wagons had posi-traction.
Motor Safe.
