I am going to replaced my rusted radiator support soon, and I would also like to replace the metal mounts that are attached to the frame. I can't find anything online the looks like it is the same. My mounts are welded to the frame, and there are no bolt or rivet holes. Here is a picture of mine:
And here is the ones that Bronco Graveyard says will work:
I don't think it would bolt up very well since the mounts are on the crumple zone. Can anyone help me find the right ones?
Did some more research on another forum, looks like 1992-1996 f150s and broncos had this style, and f250s/350s had the other style because they did't have the crumple zone. My 4 door bronco is based on a 1995 F150.
Number Dummy or anyone have a part number for the one I need?
And here is the ones that Bronco Graveyard says will work: Uh huh...
F2TZ-5A041-A (replaced EOTZ-5A041-A) .. Bracket-Frame to Body Front / Available from Ford.
