01 7.3 project questions
From what i have read so far the bellhousing from a 6.9 idi will bolt up to the 7.3 psd, but using the stock psd flywheel and clutch will the 7.3 psd or the 6.9 starter work? I wish the bellhousing from a zf6 would seperate from the transmission and make my project easier.
Any input would appreciated.
Farm tractor is what we're talking about? Does the 7.3 have enough low end torque to work with the gearing on a standard tractor or have you already figured the gearing part out?
It a 37' farmall f20 farm tractor. The original engine was like 15 hp and low torque with 4- speed transmission. Top speed is like 10 mph. Lol
The factory setup was an engine and bell housing bolted together and a small drive shaft from bell housing to transmission. My plans are to find a useable bell housing and modify it to hold a output shaft bearing and fabricate a drive shaft to go from clutch to the tractors transmission.
Im guessing im going to have to fabricate the entire bell housing but it will be fun. I like making something from nothing. This tractor will be nothing more then a toy for bragging rights possibly a far and few between weekend pulling tractor. Maybe pull a float in a parade once a year.
There is a bunch of these tractors out there with gas v8's and other odd ball engines but i cannot find one with a powerstroke. So to me it is a challange to build one.
